Run flat tires driving in cold weather ?
I own a 2016 Z51 M7. I understand your not supposed to even drive the car with these tires below 40 degrees.
Can someone explain why for me please ?
Is it that the sidewalls of the tires are too stiff ?
Is it that because these are supposed to be summer compound tires and there would be too little traction ?
If your not beating on the car can you drive with these tires below 40 degrees safely ?
Also are these tires decent in the rain ?
I live in Florida and there are not too many days below 40 degrees but, I would appreciate your input as I only own this car since Feb 2020 and I am curious.
Thank you in advance...
miss my Z06 (11-29-2020)
I drove my car home from the museum in December - Kentucky to Arizona. It was 20* when I hit the road, drove through freezing weather in Dallas with rain, sleet and snow, and 50 mph winds in west Texas. No issues at all.
The following 3 users liked this post by VETJAZZ:
Michelin states do not drive on them below 20 degrees
I drive mine all the time when the temps are in the 30's in the Am here in Georgia
. now they get slippery when cold but as long as you are careful you will be fine
When its hot out there is no better tire
Dave
Dave
Curious what you did to protect the car for the first 500 miles.... I will be driving 13 hours from museum 850 miles...any recommendations? Thank you!
PS - On C7 vettes with Z51 they wanted you to change oil after 500 miles. I am not sure that applies to the C8 your picking up though.
I am sure the museum staff will go over all the instructions on proper break in.
Have a safe trip and enjoy your new Corvette !!!
It’s due to the rubber compound of the tires. They get really hard in cold weather. I switched to the AS3 PLUS tires and for the street they are tough to beat. You can drive them in cold temps but just need to be extra careful. Wasn’t worth the risk to me. I prefer to drive mine and enjoy it in the cooler dry months.
The following 2 users liked this post by VETJAZZ:
4thC4at60 (11-30-2020),
Assuming factory Michelin Super Sport tires.
I have driven them when stuck in a cold front. I knew it was coming in, and left a few hours before. Left the hotel at 23F gingerly, and it took 20+ minutes to warm up. Once the tires were warmed up it was ok, BUT, I absolutely was very careful to not do anything radical.
The lowest the temp got was 9 F. I stopped only for gas or to pee. never both, as I didn't want the tires to get cold. There was blowing snow once I got closer to home, but that wasn't a problem since the tires were "warm".
Is it doable? YES. Do I recommend it" No.
The following 2 users liked this post by owc6:
miss my Z06 (11-29-2020),
Vette2020 (11-30-2020)
Nevermind the poor traction below 40F, below 20F, the tread and sidewalls can crack, damaging the tire, according to Michelin.
Drove my 2019Z M7 the other day around 37 degrees on run flats. Takes about 15 minutes or so for tire temp to get to normal from cool. No problems other that road service is obviously cold so traction is an issue if you get a slight bit aggressive with that 650 lbs of torque and hp. But tire wise no issues.
Moderator
Received 3,772 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
Driving in cold will also incur micro cracks in the sidewalls... these tires are terrible in mid 50 degree weather. If you must drive in winter get a different set of tires
jimmbbo (11-30-2020)
So if you have an "extreme performance summer tire" which is intended to provide maximum grip in warm temperatures, once you lower that design temperature range, the compound gets harder and no longer works the way it was designed to. All-Season tires are designed with a medium-hard compound which sacrifices some of that grip for a larger temperature range. Winter tires are harder compounds.
[ right on Michelin's web site ]
You are going to have these guys all run out and buy heaters for their garages lol lol
I live in Georgia and its nothing to have a 30 degree AM temp and jump up to 50 or 60 degrees in the PM , this is my 3rd Vette that I drive to work every chance I get , all had or have MPSS run flats all around and never have I experienced micro cracking
Dave
Location: NNCC No Name Car Crew Owned 1 C2, 2 C3's, 1 C4, 3 C5's, 1 C6, 2 C7's Now '81, '86, '03.
Received 3,950 Likes
2023 C3 of the Year Wnner - Unmodified
Drive conservatively, you'll be OK.
Received 19,565 Likes
'20-'21-'22-'23-'24
saleen556 (11-30-2020)
Received 8,997 Likes
The tread cracking issue relates to the Cup2 Tires that come on the Z07 optioned Z06s and GSs plus the ZR1. It doesn't apply to the tires you have. In NC I have driven with both the Cup2 ZPs and the PSS ZPs in mid 20 degree weather with no issues. Just like on dry warm pavement you can't drop the hammer without spinning the tires. Avoid doing sudden throttle applications and you can drive just about anywhere in any weather with the tires you have on your Z51. The issue with not being able to drive in cold weather with these tires is the driver and not the tires.
Bill
Bill
Moderator
