range unit
Old Feb 28, 2021 | 09:36 AM
Bills17n72's Avatar
Bills17n72
hey guys t appreciate all the responses that i have!!
Old Feb 28, 2021 | 10:59 PM
27ssalc's Avatar
27ssalc
Hi , did you receive my PM message to you
RSVP thanks
Frank in Mass.
Old Feb 28, 2021 | 11:05 PM
27ssalc's Avatar
27ssalc
RSVP thanks
Frank in Mass.
Old Mar 1, 2021 | 07:10 AM
slant6's Avatar
slant6
PM replied to
Old Mar 1, 2021 | 07:49 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
FYI: in some forum reply it was recommended to remove the 'Range' device and drive for 50 miles before service and car inspection. A person removed it and immediately had the car inspected and it failed. Drove some and had inspected again, passed.
Old Mar 1, 2021 | 01:23 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Mine should be arriving today. I figure I have put if off long enough. My car is not a DD and is used either stop and go traffic to work or interstate. Normally on the interstate I put it in M. Now I will just plug in the Range device and not worry.
Old Mar 4, 2021 | 01:29 PM
sharpseadog's Avatar
sharpseadog
Default Exhaust sound control
[QUOTE=Bills17n72;1603071409]ok guys im thinking about buying a range unit for my car ,it keeps the motor from switching it from V-8 to V-4 I think you just plug it in ,and do you leave it plugged in all the time , just wondering how you all like it ,thanks have a good weekend! Bill[/QUOTEust
Does the Range unit keep the exhaust sound management from going into "quiet" mode with the A8 transmission?
Old Mar 4, 2021 | 01:35 PM
slant6's Avatar
slant6
Nope
Old Mar 5, 2021 | 10:30 PM
27ssalc's Avatar
27ssalc
Hi, range finder arrived safe and sound
thanks again
Frank in Massachusetts
Old Mar 5, 2021 | 10:36 PM
Bills17n72's Avatar
Bills17n72
with the range unit plugged in ,before you start your car do you have to let it reboot itself ,or can you just get in your car and start it up and go? Bill
Old Mar 5, 2021 | 10:44 PM
Brucewrs's Avatar
Brucewrs
I just start up and go.
Old Mar 5, 2021 | 10:49 PM
27ssalc's Avatar
27ssalc
Hi if that question was aimed at me I don’t know the answer . There is too much snow for me to try it out in my car
but I’m sure someone can weigh in on your question 🤷‍♂️🤷‍♂️🤷‍♂️
Old Mar 6, 2021 | 06:59 AM
  #33
slant6's Avatar
slant6
thanks again
My pleasure
Old Mar 6, 2021 | 07:01 AM
  #34
slant6's Avatar
slant6
When you start your car it will flash for approx 5 seconds, I wait longer than that to take off range or not
Old Mar 6, 2021 | 12:32 PM
  #35
Molly815's Avatar
Molly815
slant6, I will purchase the Range AFM from you
Old Mar 7, 2021 | 06:44 PM
  #36
C7Pipeliner's Avatar
C7Pipeliner
6th Gear
Default Range AFM disable
I have a 2015 C7 A8 Z51 Stingray, I had the stuttering transmission under light loads and took it to the dealer a couple of years ago. They did the triple flush and replaced the fluid and no problems until this week. After about 7000 miles, my powertrain warranty ceased and it started again. I just ordered the Range unit and hope to receive it this week. It is very irritating to have that little stutter when accelerating lightly. I look forward to receiving the device and will provide an update later.
Old Mar 7, 2021 | 06:49 PM
  #37
Brucewrs's Avatar
Brucewrs
drive it with the paddle shifters. If it still does it the range device won’t help.
To range unit
Old Mar 7, 2021 | 06:50 PM
  #38
Bills17n72's Avatar
Bills17n72
yes please let us know C7Pipeliner!
Old Mar 7, 2021 | 08:50 PM
  #39
Ron_Attleboro_MA
C7Pipeliner: I suggest you change the fluid again. You can change the fluid yourself.
Who knows, did the dealer do a single or triple flush, did the dealer use the latest fluid, did the dealer get all the fluid exchanged.
You can use a fluid-pump to pump the old out and the new fluid in. Good, cheap enough, and worth it.
Old Mar 7, 2021 | 09:08 PM
  #40
slant6's Avatar
slant6
unfortunately I don't believe the range will fix the problem if used early or B4 Shutter it will prevent the problem. But what bruce said is true using paddle shifters will keep car in V8 mode hence same as having range plugged in. Hope I am wrong Good Luck
