Low diff oil level
Old Jul 28, 2021 | 09:27 PM
DD04C5's Avatar
DD04C5
Default Low diff oil level
I know that this has been discussed before but, I decided to change my diff oil today and drained out not quite 2 quarts of oil and filled it up with 3 quarts of oil. I would say that is low. Just putting this out there for S and G. 2017 GS approximate 20,000 miles.
Old Jul 28, 2021 | 09:30 PM
RacerRik's Avatar
RacerRik
How did the old oil look?
Old Jul 28, 2021 | 10:20 PM
mdformula350's Avatar
mdformula350
yeah i would consider that low, keep hearing they were low levels from factory for rear end and clutch so far.
im doing my 7 speed and rear end fluids soon and hoping they have at least 3/4 filled.
Old Jul 28, 2021 | 11:07 PM
DD04C5's Avatar
DD04C5
Oil was dark and metallic looking, considering it was a quart low, look like normal for the first time change.
Old Jul 29, 2021 | 01:13 AM
Avanti's Avatar
Avanti
Did you not check the level sometime along the way? These diffs are notorious for being shipped from the factory in a manner GM would label as "low," (but not the manufacturer's CEO in an old vid somewhere).
Old Jul 29, 2021 | 05:07 AM
Drive-C7's Avatar
Drive-C7
I had my 2014 Z51 7 speed and differential drained and refill by dealer last week. Although there was talk about factory fill being low on differentials from the factory my car was full ( both the transmission and rear end). This was the first drain/refill at 36,000 miles. Service manager saved some of the differential oil to show me. The oil had small bits of metal - like flakes. I read this is not a unique situation. Does anyone know what is causing this? Does it clear up with more drain/fill?
Old Jul 29, 2021 | 05:22 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Picked up my car last night from the dealer's service dept.
They did a rear diff , manual trans, clutch, and coolant service. No mention of any issues with any of them, but I am glad the car is all fresh.
It was $700 for all of the above including tax.
Old Jul 29, 2021 | 06:12 AM
SladeX's Avatar
SladeX
I changed mine at around 10k miles. It was 1 qt low and looked pretty nasty. There's no way in hell I would consider the factory fill ready for track use.
Old Jul 29, 2021 | 06:42 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Pretty much the same for me. I drained just over 2 qts. It took the full 3 quarts to fill 99%.
Old Jul 29, 2021 | 08:32 AM
ersatz928's Avatar
ersatz928
The silver particles in the oil is from the break-in wear of the ring and pinion gears. Normal, but that's why the diff gear oil should be changed early (1000 miles), and later again (5000 to 10,000 miles) to get as much of the break-in metal out of the differential.
Old Jul 29, 2021 | 08:49 AM
Corgidog1's Avatar
Corgidog1
I had my new 2015 checked by the dealer about 6 months after I got it and it was low from the factory. Probably time to have it checked again.
Old Jul 29, 2021 | 09:34 AM
JMII's Avatar
JMII
My 2014 was about 1/4 quart low. At my first track day I got a "Service StabiliTrak" warning due to elevated rear diff temps, however since changing the fluid the message has yet to return after several more track days. My fluid looked and smelled like what others have posted (IE: nasty!) So if the car is driven hard its obvious the fluid needs to be swapped out more frequently. I would also say that doing some kind of break-in fluid replacement is highly recommended too.
Old Jul 29, 2021 | 09:47 AM
RacerRik's Avatar
RacerRik
For anyone who wants to change your diff oil, I found a good deal on the AC Delco 88862624 OEM Differential Lube. They have it at a place called OEMPartSource.com for $14.49 per quart. That is about half the cost of most places I found on the web.
Old Jul 29, 2021 | 10:31 AM
Thanks RacerRik. I probably need to check and change the diff oil in my car just to be sure it is OK. Same with the tranny fluid.
Old Jul 29, 2021 | 11:16 AM
sharpseadog's Avatar
sharpseadog
Default A dumb question
Since the A8 is a trans axle unit, does the transmission share fluid with the differential or is the differential separate with a different type of fluid? Also, I had a "Service Rear Axle" error message, and the dealer replaced the oil pump. Would that have most likely included new differential oil? 🤔
Old Jul 29, 2021 | 11:20 AM
RacerRik's Avatar
RacerRik
Diff lube is separate from the transmission fluid. No idea if the dealer replaced your diff lube.
Old Jul 29, 2021 | 12:03 PM
USCG's Avatar
USCG
The trans & diff are separate units (attached to each other) and have different fluids. I changed my diff 2 years ago and saved some in a glass jar. That jar sat on a shelf all that time and the metal dust settled to the bottom leaving the actual fluid clear but a dark honey colored appearance. Definitely a lot of metal dust for the amount of fluid.
To Low diff oil level
Old Jul 29, 2021 | 10:54 PM
nmerhaut's Avatar
nmerhaut
That's a great price. I paid $63+ for 3 qts online and thought that was good.
Old Jul 30, 2021 | 12:40 PM
BostonVette's Avatar
BostonVette
I ordered three quarts...
Total was $43.47 w/ shipping
Old Jul 30, 2021 | 07:57 PM
Mad*Max's Avatar
Mad*Max
How much time in labour is the change?
