computer battery drain question
Old Dec 17, 2021 | 08:12 AM
RonF-vette's Avatar
RonF-vette
Originally Posted by Mad*Max
I would put in on a battery tender to preserve the life of the battery.
This time it was in a storage unit without electricity. In the future it should be in my garage.
Anyway, it started fine after a week.
Old Dec 17, 2021 | 09:53 AM
aklim's Avatar
aklim
I'd expect that it does. If not you have a problem somewhere
Old Dec 17, 2021 | 09:58 AM
Mad*Max's Avatar
Mad*Max
I wasn't talking about it being able to start
Old Dec 17, 2021 | 05:13 PM
RonF-vette's Avatar
RonF-vette
Ah ha. I missed the point. Thanks
Old Dec 18, 2021 | 03:39 PM
iclick's Avatar
iclick
Originally Posted by dvilin
It is so easy and convenient to hook up the charger on the C7 I plug mine in whenever it is sitting in the garage could be a day or a week or more.
Same here, even when I know I'll be driving it again the next day. Lead-acid batteries typically last longer when specific gravity is kept at optimum--i.e., fully changed.
Old Aug 27, 2024 | 12:32 PM
romandian's Avatar
romandian
so, typically there will be a draw of mabe 1 amp after switching ignition off. it will the go down is several steps, as eg interior lights go off, etc. after a few minutes i see 8 mili amps constant draw. thats how it is on my car.
if you see considerably more than 8 mili amps, you shoul start checking. pulling fuses might be the simplest way.
(dont waste your money going to a shop, imo.)
edit: connect a multimeter between one of the battery terminals and the corresponding cable. sett it to 1 amp, then switch to 100 mili amps as the current falls. should be easy.
Old Aug 27, 2024 | 03:11 PM
frankbicknell's Avatar
frankbicknell
Originally Posted by blueray16
I've had mine for 6 years now. Replaced the battery at 4 years just because it was 4 years old. I try to drive mine at least once a week all year. If its going to sit for 2 weeks or more, I plug in the trickle charger just because it there and why not?
No issues.
Since I use the charger so infrequently, I take the black bag that my charger came in and hang it over the shift **** as a reminder to disconnect before pulling out of the garage
That is a good idea. I wish I would have had a way to remind me to disconnect the shore power before leaving the dock, those shore power cords are expensive. Actually, I do have a checklist now.
Old Aug 28, 2024 | 07:28 AM
Tinkertech's Avatar
Tinkertech
Originally Posted by dbj216
My 2017 GS is sitting this winter. I have a battery maintainer. So I "charged up" the battery with the maintainer for a week or so, disconnected the battery maintainer, and measured battery voltage at 13.0 volts. Good. I let the car sit for a week without the maintainer and the battery voltage drooped to 12.3 volts. I was rather surprised. My new battery was installed the first week in July of this year. I suspect with all the electronic systems in the C7 there is a significant parasitic energy drain. I'll bet that's why Corvette provided such a coinvent connection for a battery maintainer as they knew Corvettes aren't great on winter slick roads.
Others more knowledgeable than I will surely chime in.
David
Most of the battery voltage drop was due to the 'Top' charge being removed resulting in al lower voltage reading
Old Nov 4, 2024 | 06:26 PM
Midnight_rider's Avatar
Midnight_rider
I got Costco battery. Works great. There are only 3 manufacturers that make batteries and rebranded. Buy the one that's cheap.
I had the battery drain too. I thought it was the security system that drained it, the one that senses when people get in your car without key with the top down. Either that, it's the alternator not being able to charge enough because you don't drive enough/long enough.
Old Nov 4, 2024 | 08:40 PM
user051728's Avatar
user051728
FYI this isn't a Corvette unique thing.
The number one warranty item at GM, Ford, and Chrysler right now? Batteries.
Modern cars with many many computers have all sorts of KOL (Key Off Load) problems and Quiescent Current issues. If you leave any modern car parked for 2+ Weeks you are damaging your battery SOC and if you go longer than 4 Weeks (or regularly leave it 2+) you should put it on a battery tender.
There is a two fold reason for this, one the modules drain energy constantly, but usually very very low and two the car wakes up almost everything everytime you open a door, truck, etc causing them to be awake for 1-2 minutes (should be less but sometimes modules misbehave) until after you close the door/trunk and walk away. If your car has approach detection or anything else fancy it does this anytime you get near it with your key.
So yea, if you don't daily drive, setup a battery tender. I have one in each spot in my garage.
Old Nov 15, 2024 | 05:37 PM
seagravesg's Avatar
seagravesg
C7 battery drain noticeable after sitting 7 - 10 days. I have maintainer generally used in winter. Plan to use more often.
Question: as battery attach plug is in trunk, is best approach to plugging maintainer to AC outlet to run cord out of trunk and close trunk hatch (easily) on cord so all interior lights cancel?
Old Nov 15, 2024 | 06:07 PM
C7nut's Avatar
C7nut
You are right, I have a 2016 C7 and I use the battery charger just about every time the car is in the garage and it's still the original battery after 8 years.
I am thinking of replacing it before I store the car for the winter. But, I said that last year
Old Nov 15, 2024 | 09:32 PM
  #33
aklim's Avatar
aklim
Not sure where you read that so let me ask. Did that article say why? A lot of them sit in the engine bay and are heat-cold cycled very often which can't be good for the battery. It is also shook around and the acid sloshing against the plates might also be an issue.
Most interesting question would be "How worth it is daily plugging in?". Battery is about $200 so how much life are you really saving by plugging in whenever it is not driven? I agree that after a couple of weeks we could have a problem but I wouldn't bother to plug it in when it isn't driven.
Old Nov 16, 2024 | 11:37 AM
  #34
user051728's Avatar
user051728
Not an article on the failures. In the industry so you see the data.
Old Nov 16, 2024 | 01:24 PM
  #35
redman76's Avatar
redman76
St. Jude Donor '09
This is what I do as well. Plug it in and close the hatch. Never had any issues with this method. You don't have to worry about leaving the hatch open because the interior lights are on a timer and will shut off automatically after about 15 min. I close my hatch to help prevent any 4 or 8 legged critters from getting in.
Old Nov 17, 2024 | 02:20 AM
  #36
SoCalDavid's Avatar
SoCalDavid
Thanks. Don't need anything fixed now. But this is the first time the car will be sitting for a week or so without use. Battery is just turning 4 yrs old.
I replaced the original battery in my C7 (2016) as a precaution last year. I would often go a week or two without driving the car. Even with a 7-year-old battery, I have never had any problems, and I have never attached a trickle charger to the car. I would be concerned if your 4-year-old battery didn't start the car after a week or so.
