Quick jack question
Old Dec 18, 2021 | 08:46 PM
Vette Ski's Avatar
Vette Ski
Default Quick jack question
Hello,
I have a Q.J 7000 and just installed a set of wheels on them for ease of moving them around. I know in the instructions it says not to raise them without a load ( vehicle) on them. I have seen on you tube them being raised without a vehicle on them ? Did I just answer my own question . What say you all ?
BTW HAPPY HOLIDAYS !!!
Thanks for looking ,
Rich
Old Dec 18, 2021 | 09:06 PM
CB56's Avatar
CB56
I have the 7,000 and I haven't found a reason why you can't. It's just hydraulics. If they won't come all the way down just hold the button and stand on them.
Old Dec 18, 2021 | 09:10 PM
Vette Ski's Avatar
Vette Ski
That is what I thought, I am only 165 lbs. but that should work with my neighbor on the other one.
Thanks,
Rich
Old Dec 19, 2021 | 08:40 AM
BELVIN20's Avatar
BELVIN20
I use my Quickjack 7000 to raise my lawn tractor so I can remove the blades to sharpen them, Quickjack works great for that as well.
Old Dec 19, 2021 | 09:33 AM
Dcasole's Avatar
Dcasole
Just make sure you have air in the air cylinders, that's what brings the jack's completely down
Dave
Old Dec 19, 2021 | 09:40 AM
Flame Red's Avatar
Flame Red
One other tip. When you connect the hoses, press the down button on the pump. If you don't the connections are sometimes hard to make and you can end up ruining the quick disconnect fittings.
Old Dec 19, 2021 | 11:13 AM
Vette Ski's Avatar
Vette Ski
And make sure you check your air pressure, it does lose pressure. I found mine down to 34 lbs. after a while.
Rich
Old Dec 19, 2021 | 11:15 AM
Vette Ski's Avatar
Vette Ski
I did find connecting the hoses troublesome if this is not done, great point .
Rich
Old Dec 19, 2021 | 12:50 PM
Chevyrelic's Avatar
Chevyrelic
Originally Posted by Vette Ski
Hello,
Rich
Can you post a picture showing how/where you added wheels to your QJ? TIA…
Old Dec 19, 2021 | 08:58 PM
Vette Ski's Avatar
Vette Ski
This was a mix of what you see on you tube and my own creation. I used a 5/8" threaded rod ( overkill ) 1/2" would suffice, 15 1/2" long . I just happened to have the 5/8" laying around. I used 1/8" steel and bent it 2 3/4" long for the wheel mounts and 1 3/4" long to mount to frame. I purchased the wheels on Amazon
I mounted the ( 2 1/2" ) high wheels 2 1/2" from the end by drilling into the frame and using self tapping heavy screws.
Hope this is helpful,
Rich
Only 6 fit on this post, to be continued -------
Old Dec 19, 2021 | 09:03 PM
Vette Ski's Avatar
Vette Ski
Continued ----
Hope this is helpful !!
Rich
To Quick jack question
