Wheel locks
Old Sep 1, 2022 | 10:04 AM
prowlernfo's Avatar
prowlernfo
Default Wheel locks
Bought a car from out of state, it's got wheel locks on it and of course they cannot find the key. Would the local dealership be better able to handle this or will it be the same process as any garden variety tire center? Thanks.
Old Sep 1, 2022 | 10:20 AM
rtv900's Avatar
rtv900
I had the same issue once with a wheel lock and I ended up having to go to the dealer (nissan in this case) where they have a gigantic "master set" of probably 50 various styles.
I called tons of places and they all said they don't have those things, only a dealer.
Old Sep 1, 2022 | 10:27 AM
madrob2020's Avatar
madrob2020
If they aren’t high end hard to defeat types then a dealer or tire shop may be able to get them off. You don’t want to destroy them trying to remove since that would create an even bigger problem. Have you checked the small cubby storage box in the cargo area-driver side? There’s also a storage area in cargo space on passenger side beneath the carpet where battery is that is for storing a tow ring (which doesn’t come with cars in US). It has a cutout that would be ideal for wheel lock key. Good luck 👍
Old Sep 1, 2022 | 10:32 AM
Richard Ames's Avatar
Richard Ames
Were they the factory option the "key" is tied to the VIN and a dealer can get it. If aftermarket. you may be able to take a picture or two if the dealer does not have the correct "key" to get one off to send to the manufacturer to get the "key" Some hammer a socket on the lug nut and remove that way as a last resort (like thieves do). .
Old Sep 1, 2022 | 11:00 AM
Maxpowers's Avatar
Maxpowers
Did you you check the hidden cubby in the trunk? Otherwise Id try the dealer first.
Old Sep 1, 2022 | 11:01 AM
prowlernfo's Avatar
prowlernfo
Gotta admit, did not know about the storage on the passenger side in the back, I'll definitely check there when i get home from work and fingers crossed.
Old Sep 1, 2022 | 12:08 PM
Maxpowers's Avatar
Maxpowers
There is also one in the floor...rear drivers side.
Old Sep 1, 2022 | 01:02 PM
madrob2020's Avatar
madrob2020
see post 3
Old Sep 1, 2022 | 02:16 PM
JohnKyJones's Avatar
JohnKyJones
If all else fails you can find a shop that has the reverse threaded removal sockets.
It's like a socket but has reverse threads inside that cut/dig into the outside of the lug as it removes it.
You won't be able to reuse the lock lug but you'll have it off.
Had to buy a set for home use when I lost a key for a car was selling.
Also see if perhaps the previous owner stored the lock lug key code card in the owners manual.
If so order a replacement.
Old Sep 1, 2022 | 02:41 PM
Grand Slam's Avatar
Grand Slam
I assume you've looked in the glove box and the compartment behind the screen. You do know about the hidden compartment?
Old Sep 1, 2022 | 03:30 PM
Flattman's Avatar
Flattman
I'd also check in any paperwork you received with the car or in the glove box / owner's manual envelope. If they're aftermarket a key card usually comes with them you can use to order a replacement. Maybe they put it there?
Old Sep 1, 2022 | 03:45 PM
c5arlen's Avatar
c5arlen
I remember back in the day on an old Mustang I had the key lug nut was missing it's key.. the tire shop used a socket from a socket wrench set, hammering it over and on to the lock-nut and wrenching it off... Worked!
Old Sep 1, 2022 | 04:47 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
That's the quick and dirty way to do it. Of course, you destroy the lock but usually no damage to the wheel. If you only have 4 locks instead of 20, I'd go for it if I couldn't find the key.
Use a 12 pt socket, just large enough to start slipping onto the tapered outside of the lock. Might need to use a metric to get the best fit. Use a deep socket, extension, or something so you don't hit the wheel with the hammer. May need to buy more than 1 socket, maybe 4, if it gets ruined by the hammering.
Old Sep 1, 2022 | 07:39 PM
Avanti's Avatar
Avanti
Sorry about your plight. Simply one more reason never to use the things.
Old Sep 1, 2022 | 11:27 PM
Hopefully you are able to either find the key or the card which has the key number on it. If not, try either your dealer or a high end wheel shop.
Old Sep 2, 2022 | 08:18 AM
wrecker3's Avatar
wrecker3
Get a 12 point socket and hit with a hammer and you can get it off.
Old Sep 2, 2022 | 08:20 AM
Walt White Coupe's Avatar
Walt White Coupe
To Wheel locks
Old Sep 2, 2022 | 08:24 AM
DGA3's Avatar
DGA3
Originally Posted by Walt White Coupe
Yikes!
Old Sep 2, 2022 | 08:39 AM
wrecker3's Avatar
wrecker3
Wheel Locks will not deter a Wheel Thief. It will just **** Him Off.
Old Sep 2, 2022 | 10:37 AM
Maxpowers's Avatar
Maxpowers
True that. But if you have two equally desireable cars in a parking lot. One with locks and one without....I expect them to go for the latter.
