Battery Replacement
Old Nov 23, 2022 | 09:04 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Battery Replacement
I am likely going to be changing my battery shortly and was wondering how much it will affect the cars memory, as far as the memory seats, radio stations, and other items.
Popular Reply
Nov 23, 2022, 10:01 AM
Jacob's Avatar
Jacob
C7 Battery Replacement
For those looking to replace your C7 battery, here is an attractive alternative to the OEM AC Delco battery; the Energizer AGM battery from Costco (Canada) or Interstate AGM (Costco USA).
Here is a very helpful video on the installation:
Here is the Costco listing for the battery (delivered):
https://tires.costco.ca/Batteries/SearchResultsByVehicle?lang=en-ca&batteryType=Automotive&Year=2017&Make =Chevrolet&Model=Corvette&Engine=V8-6.2L-Gas~V8-6.2L-Gaz
Besides being superior to the OEM battery, this AGM battery is much easier to work with. The Energizer has built-in handles which facilitates lifting in and out. Worth noting is the rubber venting hose which fits into the side of the battery and exits at the battery compartment floor. It should be removed from the battery prior to lifting the battery. It has a right angle elbow which is easily broken. (I know).
Costco gives you $10 for returning the old battery.
JACOB
2017 Z06/Z07 Coupe Admiral Blue - M7
Old Nov 23, 2022 | 09:23 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
It will lose absolutlely nothing except the index of the windows. All radio, seat location, whatever will be retained.
2014
Window Indexing and
Express-Up Reset
Window indexing may be required if
the vehicle battery has been
recharged or disconnected, or is not
working. Express-up and the
convertible top will not function until
the windows are reset. After battery
power is restored, a message or
code displays in the Driver
Information Center. See Driver
Information Center (DIC) on
page 5-23.
Once power is restored:
1. Close the doors.
2. Start the vehicle.
3. Hold the window switch up to the
fully closed position.
Window Indexing and Express-Up Reset
Window indexing may be required if the vehicle battery has been recharged or disconnected, or is not working. Express-up and the convertible top will not function until the windows are reset. After battery power is restored, a message or code displays in the Driver Information Center. See Driver Information Center (DIC) on page 5-23.
1. Close the doors.
3. Put windows down
4. Raise each window and hold the window switch up in the fully closed position for a few seconds after the window is up.
Elmer
Old Nov 23, 2022 | 10:01 AM
Jacob's Avatar
Jacob
JACOB
Old Nov 23, 2022 | 10:14 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I watched this video on YouTube a few days ago and I noticed he never mentioned disconnecting the vent hose or reconnection it. Only mentioned the white cap and the piece that goes to the hose.
Old Nov 23, 2022 | 10:31 AM
with what Elmer said. Only the windows need to be re-indexed.
Old Nov 23, 2022 | 11:02 AM
eboggs_jkvl
Moderator emeritus
Something about wearing watches and rings when changing out a battery reduces my confidence in the instruction.
http://netwelding.com/Battery_Issues.pdf
Props to JerryU
Elmer
Old Nov 23, 2022 | 11:18 AM
Maxpowers's Avatar
Maxpowers
+1 on JerryU's guide.
I will add when I changed mine to AGM I just re used the OEM vent tube.
Old Nov 23, 2022 | 02:27 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
You do not signify if it is a convertible or not. If it is a convertible, take the carpet completely out and your job will be much easier.
As I mentioned in another thread, I have stuck with the AC Delco through a C4, C6, and C7 with no problems. I replaced the battery in the C4 twice, in 18 years. It had 84,000+ miles on it, when I sold it.
Old Nov 23, 2022 | 03:57 PM
9sec's Avatar
9sec
typically there isnt any vent tube on a agm battery since its a sealed unit. cant ad water or vent. I just installed a interstate agm battery in my z06 no vent tube or place for one
Old Nov 23, 2022 | 07:46 PM
Kevin A Jones's Avatar
Kevin A Jones
Same here, with the OEM type Delco typically lasting 6-7+ years in a C7 at a very reasonable price, don't really understand changing to AGM, especially considering issues associated with some.
Old Nov 26, 2022 | 06:32 PM
dprestidge's Avatar
dprestidge
I have had the battery out of my 2015, 2LT, Z51, M7 Corvette twice. Last time was last Friday. Both times the battery was out of car at least 24 hours. Neither time did I lose anything but the radio lost the channel it was on, didn’t lose presets or window indexing. I’ve heard you have to redo everything and the manual tells you how, but I didn’t have to. Good luck!
Old Nov 26, 2022 | 11:27 PM
Anthony j's Avatar
Anthony j
just had mine replaced , only lost the radio stations , that’s it. Good Luck.
Old Nov 27, 2022 | 08:54 AM
eboggs_jkvl
Moderator emeritus
I've never heard of anyone losing the memory of the radio stations.
Elmer
Old Nov 27, 2022 | 09:53 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I replaced mine this weekend. Everything was saved and I even had instruction on the DIC to index the windows. Ended up with a Diehard. Could not fine the AC Delco anywhere including the Chevy dealer.
I would however love to sit down and talk to the design engineer that thought that the location and access to the battery was a good idea. Seems to me it would have been nice to make it an access panel like the storage compartment on the driver's side directly across from the battery location.
Old Nov 27, 2022 | 10:27 AM
eboggs_jkvl
Moderator emeritus
Do I detect a tone of displeasure in your comment about GM engineering? 'Tis a bit of a bother to replace the battery for sure.
Elmer
Old Nov 27, 2022 | 10:51 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
1 Thing I will recommend, be sure to disconnect elbow breather from battery, many break that thing off trying to get battery out.. it is a pain. I used soft tie down extensions as handles.
Old Nov 27, 2022 | 11:28 AM
Walt White Coupe's Avatar
Walt White Coupe
Just a reminder that the stock battery has a folded down handle that is kind of hidden. Using the handle makes it a lot easier to remove.
I'm still not convinced that the AGM battery replacement is the best choice. That is the recommended replacement and what I used. I'm sure that the charging voltage is higher and stays higher than it was for the original "flooded" cell battery. I've seen numbers as high as 15 volts and never saw that on the original. I'm hoping that that increased voltage is not going to prematurely age the battery. If you google charging an AGM battery vs a flooded cell battery, you will find that many sites say the two types of batteries need different chargers because of the different design configurations. Time will tell.
To Battery Replacement
Old Nov 27, 2022 | 12:00 PM
Maxpowers's Avatar
Maxpowers
My OEM battery didnt have any sort of folded down handle.
Old Nov 27, 2022 | 12:18 PM
Walt White Coupe
Like I said, the handle is not obvious. When I brought the old battery to the store for recyling I pulled the battery out of my car with my rubber strap that attaches to the posts and set it down and took the strap off. The store employee then reached down, pulled up the handle(s) and walked away with it. Sure surprised me.
Old Nov 27, 2022 | 12:25 PM
socal_tom's Avatar
socal_tom
That right there is the only reason I did not go OEM battery because no fold down handle . It's just to hard to pull and install a battery with out a handle for me
