Basic winter question…
Old Dec 15, 2022 | 07:39 AM
  #61
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
Originally Posted by silverback v8
Tipp:
Buy an extension from CTEK. So you can close the hatch complete. There is enough space that the cable will not be damaged.
Reason: the car will not fully shut down when hatch ore engine hood is open (sensors!)
Why is this a problem when the battery is being charged?
Old Dec 15, 2022 | 07:50 AM
  #62
silverback v8's Avatar
silverback v8
My dealer told me, that it is not only a problem with voltage, but also with security. The car will not be fully armed.
Old Dec 15, 2022 | 08:04 AM
  #63
rtv900's Avatar
rtv900
the hatch closes just fine with the charger as is, the cable is fine
not sure why people think it can't be closed
Old Dec 15, 2022 | 08:08 AM
  #64
Kevin A Jones's Avatar
Kevin A Jones
Not a problem as is in a locked garage and I assure you that I'm fully armed even if the Corvette isn't.
Old Dec 15, 2022 | 08:11 AM
  #65
Kevin A Jones
I don't believe it can't be closed, I just prefer not to.
Old Dec 15, 2022 | 08:19 AM
  #66
silverback v8
I´m sure that in your country it´s easier to protect youself and your Corvette, but not in Austria
Old Dec 15, 2022 | 08:22 AM
  #67
Carvin's Avatar
Carvin
Ditto.
Old Dec 15, 2022 | 08:29 AM
  #68
Kevin A Jones
Yes, but seems to be getting harder and harder here everyday.
Old Dec 15, 2022 | 03:22 PM
  #69
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Tipp:
The CTEK extension is a nice idea, though I don't mind my trunk being ajar slightly for some air flow. Mice and chipmunks can get in even if the car is completely closed up, as we have experienced.
After about 15 minutes, the interior lights shut down.
I'm not sure what remains "alive", but it's very low current draw. With the Corvette CTEK plugged in, 99% of the time when I walk past the car the unit shows fully charged and no charging actually happening. Very occasionally, it will start charging to top off the battery as I walk by, but that only lasts for maybe 5 seconds.
Old Dec 15, 2022 | 08:04 PM
  #70
Dragon Rider's Avatar
Dragon Rider
Default Basic winter questions
Driving the car once every 30 days or so should present no problem. I used to do this when I lived in upstate NY. Usually, the roads were clear at least once every 30 days, although there was one winter when I went 60 days between driving the Corvette. At the time I didn't keep the car on a battery tender but didn't have any problem starting the car after it spent 60 days in a cold garage.
If you do this make sure you drive the car at least 35 miles in varying conditions including more than half the miles on the highway at speeds higher than 55 mph. This will make sure the battery is fully charged when you put the car back in the garage, moisture in the exhaust system has evaporated, lubricants in the engine, transmission and differential have been splashed every place they can be splashed and have gotten hot enough to evaporate any condensed moisture and all seals in the engine, transmission and differential have been lubricated. It is also good for your mental well being since a long drive in a Corvette is enjoyable and soothing to the soul. It is hard to feel depressed during short winter days when you are looking forward to or are actually driving the Vette for an hour or so. The key thing to remember is GM nor any other OEM didn't design the cars to sit around and not be used. There is no special design case for that scenario. They are meant to be driven and last longer when driven. Another thing to remember is don't just back the car out of the garage and let it idle for 20 minutes. That is far worse than letting it sit. When the engine is running you need to be driving.
Bill
From Army aviation experience’ if the aircraft is not used, it will become a hanger queen.
