Is This Normal?
Old Mar 5, 2023 | 09:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by Dcasole
Bingo ..... if it's never done it before and it has not been topped off lately then the cap is not holding preasure .... which if left will eventually cause it to run hot as the coolant needs to be under pressure, running just a bit hotter than normal , almost undectable leads to the "puking" that you are seeing
Dave
I'm thinking that initially the engine will not run hot, the thermostat will still open/close to keep the specified temp regardless of tank pressure.
But at some point the lack of pressure in the tank will allow the coolant to boil, either during normal driving, shortly after shutting down, or when the coolant gets hot from hard driving. Then, serious overheating could come on quickly.
I think that makes sense, but no guarantee...
Old Mar 5, 2023 | 09:05 PM
aklim's Avatar
aklim
AFAIK, the higher pressure delays boiling or raises the boiling point. As long as it is circulating coolant and the radiator takes the heat away, life is good. OTOH, when you shut down and the radiator isn't able to move the heat away, it boils.
Old Mar 13, 2023 | 05:36 PM
PhxMark's Avatar
PhxMark
Well, nothing else has dripped out of the overflow tube, temperature is as normal as ever and a pressure test revealed no leaks.
Don't know if the new cap helped but it didn’t hurt, especially at $10.
Old Mar 13, 2023 | 05:38 PM
Skid Row Joe's Avatar
Skid Row Joe
Might have been topped off, a little too high in the expansion chamber.
Old Mar 13, 2023 | 05:48 PM
PhxMark's Avatar
PhxMark
When this all started I noticed the overflow tank appeared to be a little over the “full” mark.
It’s really difficult to see and get an accurate reading. Fortunately it’s not super critical.
Old Mar 13, 2023 | 06:32 PM
Skid Row Joe
My (bought new) 10K miles, 2017 Stingray base's expansion bottle is low, I've noticed. Don't recall if it was full years ago. The liquid is Yellow color in there. Wonder if I can buy this coolant if specially prescribed, @ Walmart or AutoZone??
Old Mar 13, 2023 | 07:19 PM
PhxMark's Avatar
PhxMark
Mine is filled with Dex-Cool and it’s orange. You can buy it anywhere. When did you last change yours?
Old Mar 13, 2023 | 07:24 PM
Highplains's Avatar
Highplains
When it was all said and done, this is what I think was my problem. Mine filled too high, I believe. Once I fixed that, I have not had a lead since
Old Mar 13, 2023 | 07:32 PM
aklim's Avatar
aklim
I never buy the generic coolant that is "one size fits all" but any auto parts store should have Dexcool.
Old Mar 13, 2023 | 11:16 PM
Skid Row Joe
Great! THX for the info!
Never. It's a 2017, 10K miles.
Old Mar 14, 2023 | 12:52 AM
PhxMark's Avatar
PhxMark
I see..
Old Mar 14, 2023 | 07:34 AM
aklim's Avatar
aklim
Isn't the coolant a 5 year deal?
Old Mar 14, 2023 | 10:47 AM
  #33
PhxMark's Avatar
PhxMark
Yes, my manual says 5 years or 150,000 miles, whichever comes first.
