Battery
Old Apr 28, 2023 | 08:15 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
Originally Posted by eboggs_jkvl
Were I doing it:
Buy the part shown in post #7
Remove the negative cable (Be nice to the thin black wire on the negative cable(don't break it!!!))
Remove the positive cable
Replace the fuse block with the stripped post
Attach the positive cable
Attach the negative cable (Be sure you were nice to the thin black wire on the negative cable or repair the broken wire with SOLDERED connections)
Index the windows. (All the other things in memory are just fine and will still be there)
Elmer
Recently had mine swapped out at a local dealer. Got it home and just before pulling in the garage, the battery warning light came on. Looked in the battery compartment, and sure enough, the infamous little black wire was disconnected. A simple fix.
Called the dealer, and they wanted me to bring it back, an hour and a half drive. I told them I'd fix it myself, and they refunded the installation charge.
