C7 x-pipe options
Old May 11, 2023 | 03:44 PM
oaklawn's Avatar
oaklawn
Cruising
Default C7 x-pipe options
Hello C7 owners. I need your input on trying to get my 2018 C7 Stingray a little louder. Currently everything is stock and I'm thinking about possible removing the cats near the mufflers. The only problem is that I noticed that Corsa and Borla no longer sell the catless x-pipe. I have seen on ebay that they sell something similar, but it's 2 pieces and it comes with clamps. I was either thinking of going to a muffler shop and having them cut off the cats and weld on an attachment to the current pipe or I can buy the ebay product (2 pieces) and take it the the muffler shop and have them install it and also weld on the 2 pieces. Not sure how much of a sound difference it would make removing the cats. Would it be a little louder? Also, anyone that did this have problems passing the emissions test?
Old May 11, 2023 | 04:27 PM
flynhi's Avatar
flynhi
Haven't tried this on y C7 but I did on my C5. No increase in sound level but a small increase in HP, TRQ.
Your results may be different.
Old May 11, 2023 | 04:35 PM
car2fast4you's Avatar
car2fast4you
I'm using this Corsa Double Helix knock-off on my Z06. It's well-made, and it fits perfectly. FYI - all C7's use the same x-pipe.
https://cornerstoneperformancesoluti...42447001944318
I can't tell you how much sound difference it made because I installed it at the same time as Corsa Xtreme mufflers.
I initially had only purchased the x-pipe. But after "exhaustive" research, I convinced myself that it wouldn't be loud enough for my taste. So, I opted to install new mufflers as well. I'm glad I did.
If you like an even "slightly loud" and/or deep exhaust note, I don't believe that you will be satisfied with just the x-pipe. If I could only choose 1, I would go with the mufflers instead of the x-pipe.
And since you asked, removing the secondary cats from the x-pipe will not affect the emissions test.
Old May 11, 2023 | 05:24 PM
Ken_4fun's Avatar
Ken_4fun
I got a Manzo off ebay for $200. Its catless and fit was perfect.
Its just 2 pipes. Paying a ton for a name brand is silly.
Your mileage may vary.
Ken
Old May 11, 2023 | 06:44 PM
Pineapple's Avatar
Pineapple
Assuming you car has the factory NPP dual mode exhaust on it, adding an X-pipe would make it ~25% louder under normal acceleration and ~75% louder WOT. That's the setup I have and I think it perfect. It will have the same tone as stock while being louder when you want it to.
The purpose of the x2 small secondary cats on the stock mid-pipe is to reduce emissions on startup, once the car is warmed in they don't really do anything to further clean the air so they will pass the sniffer test once warmed up. The Borla and Corsa X-Pipe (discontinued) both look just like factory once installed plus the aluminum brace covers most of it so I'm fairly certain the smog technician won't be able to tell it's aftermarket.
It's unfortunate Borla and Corsa and possibly AWE discountied the X-Pipes due to the EPA cracking down on manufacturers but I would be wary to buy Manzo's product. If possible and your situations allows, try to source responsibly.
Old May 12, 2023 | 06:05 AM
mdformula350's Avatar
mdformula350
just get one Ken mentioned or the EOS, it will resolve your situation for cheap.
not worth the effort modding your stock xpipe, id keep it intact and buy replacement aftermarket. that way you can return to stock.
no emissions issue, especially since they are not monitored and there is a tunnel plate that covers stuff.
https://extremeonlinestore.com/colle...7e59f781&_ss=c
looks like eos is out of stock again, so that might be your issue currently.
you can try to find used as well.
good luck.
Old May 12, 2023 | 09:40 AM
GSCE#456's Avatar
GSCE#456
This is not true at all. I added the Corsa X-Pipe and I honestly couldn’t tell a difference at all. I “wanted” to hear a difference, but honestly couldn’t tell at all.
Then I added the Corsa headers to the X-pipe and kept the stock NPP exhaust. That made a HUGE difference.
After a few months I decided the drone was too bad when the NPP exhaust valves opened up, so I went all in and added the Corsa Extreme Variable exhaust. WOW! Now it’s loud enough to scare kids and adults out of their shoes.
It’s PERFECT now!
Old May 12, 2023 | 11:29 AM
oaklawn's Avatar
oaklawn
Cruising
Thank you for the info and link. So on my 2018 C7 Stingray I noticed that I don't have NPP valves so switching from ECO to Track I wouldn't think makes a difference since there are no valves that close. What you described that's exactly what I'm looking for "slight louder/deep exhaust note". Is the x-pipe on the link you sent catless? I will also do some research on the Corsa Xtreme muffler.
Old May 12, 2023 | 11:31 AM
oaklawn's Avatar
oaklawn
Cruising
Ken
Thanks for the info Ken. Did you just add the xpipe or also new mufflers? What sound difference did it make?
Old May 12, 2023 | 11:40 AM
oaklawn's Avatar
oaklawn
Cruising
It’s PERFECT now!
Thanks for the info. I think I might try to get a catless x-pipe and also add either Corsa or Borla mufflers. I think it should make a nice difference in the sound. I'm not looking to add headers since I think if I add those I would need to get the car tuned.
Old May 14, 2023 | 10:47 PM
Avanti's Avatar
Avanti
I cannot speak for louder since that's the last thing I want... to yell at gendarmes to look at me. But, if you find an X-pipe you like and cannot locate one for sale, If you can get a decent picture and take it and your car to a good muffler shop they should be able to fab a dupe and install it for you. All the best.
Old Feb 26, 2024 | 10:06 AM
brumfield8's Avatar
brumfield8
1st Gear
…which muffler model did you get and where did you order it? ‘Thanks
Old Feb 26, 2024 | 11:01 AM
103FamilyRacing's Avatar
103FamilyRacing
Cornerstone Performance makes a good cat-less x pipe
Old Feb 26, 2024 | 12:39 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
After a lot of research, I decided on the Extreme Online Store's (EOS) X-pipe. Very happy with the quality and fitment of their x-pipe assembly. Installation is very reasonable as long as you have the tools and medium mechanical skills. Don't let the two piece assembly scare you away. If anything it allows for a little more flexibility during installation. AND you can't beat the $260 price!!
The link below is to a thread that discusses the installation process. I made the link take you to where @MA ZO6 starts discussing his installation. As you read down the page I added some additional information that might prove helpful if you go the EOS route.
EOS X-Pipe Thread
Old Feb 27, 2024 | 10:39 PM
tlrskunk's Avatar
tlrskunk
https://speed-engineering.com/collec...t4-lt5-engines
I went with this one. with stock NPP it's noticeably better sounding. i went this route as it's one piece unlock the EOS that has a Middle joint that gets clamped. Install was super easy on a lift even after driving the car to my buddies house and doing it while everything was still hot/warm from the drive. 10/10 would buy the same set up again.
Old Feb 28, 2024 | 07:50 AM
DC 155's Avatar
DC 155
EOS has the one piece X-pipe without the cats. I did that first and thought it sounded slightly throatier, not really louder.
Did AWE touring set up last year at Carlisle and that completed the sound.
Old Feb 28, 2024 | 12:56 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
I'm curious when they offered the one-piece X-pipe? All I have ever seen was the version with the two sections that clamped in the middle.
To C7 x-pipe options
Old Feb 28, 2024 | 01:03 PM
tlrskunk's Avatar
tlrskunk
They Never have. It's always split in the middle.
Old Feb 28, 2024 | 01:42 PM
car2fast4you
My guess is that the EOS pipes are manufactured overseas. Splitting the pipes into 2 pieces allows them to fit in a much smaller box, thus cheaper to ship.
Old Mar 12, 2024 | 08:02 PM
user051728's Avatar
user051728
I don't think they make it anymore but if you can find an AWE Catless X-Pipe they are the best. I have one on my NPP and in silent it's still silent but in track its LOUD just the way I like it.
