Launch control problem
Download the pdf version of the owner's manual from the Sticky Threads link above and read section 9.
Ron
GM added launch control for you to use and as long as you don't get axle hop you will not have any issues
OP , you are doing it right , I am assuming that you don't have a Z51 and and you have an A6
You are doing everything right except
1 - Stand on the brake pedal like you are having to do a panick stop , press it thru the floorboards
2- quickly press the gas pedal to to the floor . RPMS will only go to 2100 RPM
3- let go of brake and hold on lol lol .
I can pop a 1.6 to 1.8 60 ft time on an unprepared track with the factory run craps . You can get faster times not using launch control but its a fine line between a good launch and blowing the tires off of it . If you are not using launch control you must let off of it at the first sign of axel hop , axel hop will break stuff real fast
When I run drag radials I don't use launch control, I just roll into the throttle real quick keeping the tires just on the brink of spinning ..
Don't be scared of it , Launch control is fun
Dave
