Splitters
Old Oct 5, 2023 | 12:27 PM
paulam's Avatar
paulam
Cruising
Default Splitters
Thanks for all the replies. I should mention I am new to this site. Not new to corvettes this is my third one first two were C4s. Glad i got onto it this site. Thanks again to everyone.
Old Oct 6, 2023 | 05:25 AM
LOTO1953's Avatar
LOTO1953
I installed an EOS stage 2 splitter on my C7 a couple of days ago and no problems at all with fitting securely or finish. Easy install without jacking up using a 1/4" ratchet and my cost delivered was $224.98 with no end cups. I ordered the primer black model and might pull it off over the winter and paint/clear it...installing side skirts this weekend.
Old Oct 6, 2023 | 07:00 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
Originally Posted by paulam
thanks - just for looks
Most manufacturers will give you what you are looking for. Just depends on what you want to spend.
Again, I am happy with mine from EOS....
Old Oct 6, 2023 | 12:20 PM
Racer1735's Avatar
Racer1735
Here's my EOS Stage 2 spoiler, prior to installing the end winglets. I just drove up on a set of Rhino Ramps and screwed/riveted the assembly on. Screws went in original holes and I drilled (using the splitter template) for the rivets. Purchased mine, in Carbon Flash Metallic, from JW Motorsports for $399.97 and had it (as well as skirts and spoiler) within a week.
Old Oct 6, 2023 | 12:56 PM
paulam's Avatar
paulam
Cruising
Thanks I will check that out. Price is right
Old Oct 8, 2023 | 11:26 PM
Avanti's Avatar
Avanti
They are often an easily damaged item. If I were going to have one (and I don't), I'd sure not go with the most expense I could find. All the best.
Old Oct 9, 2023 | 12:44 AM
paulam's Avatar
paulam
Cruising
Thanks - the EDS looks right. They have a good video of the install. I'm going to wait till Black Friday see if they go on sale.
Old Oct 9, 2023 | 10:35 AM
Punisher44's Avatar
Punisher44
You don't have to wait. I was doing the same thing waiting to see if they do a black friday sale. They do every year for 10%. Did a search it's always 10%. Here is a 10 % code I just found and ordered my splitter 2 minutes ago CORVETTECHANNEL
Old Oct 9, 2023 | 03:12 PM
Blackwater0323's Avatar
Blackwater0323
ACS is top quality. It is solid and finished on both sides. I have unfortunately scraped a curb a couple of times. No damage other than the underside had a scuff. Rubbed some black trim restorer on it and looks brand new.
Old Oct 9, 2023 | 04:38 PM
paulam's Avatar
paulam
Cruising
thanks
