Splitters
Old Oct 4, 2023 | 02:59 PM
paulam's Avatar
paulam
Cruising
Default Splitters
Splitters - hello - going to install a splitter on my 2014 C7.
I have looked at the ACS models and they look fine. I see their prices are quite a bit more than other after market suppliers. Are the ACS top quality and the less expensive ones inferior? Thanks
Old Oct 4, 2023 | 03:05 PM
Travlee's Avatar
Travlee
i have the C7Carbon Z06 style stage 2 on mine... good quality and fitment
https://c7carbon.com/product/corvett...h=carbon-flash
you will get all kinds of answers, some will like one thing, others another
Old Oct 4, 2023 | 03:06 PM
Punisher44's Avatar
Punisher44
You will get different opinions, here is mine. EOS quality is fine for something you can damage easily and is located so close to the ground. They have it on Amazon with side wings for 350.00 can't beat the price. I will be getting one but waiting to see if they go on sale for Black Friday. Even if they don't it's a great price. Now other splitters may look a little better but cost hundreds more. Just my .02
Old Oct 4, 2023 | 03:13 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
If you want it to look perfect and no fit or installation issues go for ACS.. if you don't mind fiddling around and getting things to fit then save a few bucks and get one of the others. You really do get what you pay for in my book... been bit in the *** many times trying to save a few bucks.. your choice
Old Oct 4, 2023 | 03:21 PM
Raidercop's Avatar
Raidercop
I went with a cheaper one bc its so easy to bang them up
Old Oct 4, 2023 | 03:34 PM
Travlee's Avatar
Travlee
my first one was a Corvette World one, supposedly from the original molds... but it was thin and hollow, a tire tread on the hwy eventually took it out. the C7Carbon one is def sturdier. nailed a good size jackrabbit on the way to work one day, all i got was a scratch
Old Oct 4, 2023 | 03:37 PM
Racer1735's Avatar
Racer1735
The difference that is apparent is that ACS build what I call a 'completely enclosed' splitter. The top, bottom, sides, front and back are one continuous enclosed piece. The EOS splitter is an 'open-bottom' piece, meaning that the splitter is molded in such a way that there isn't really a 'bottom' to it. You have a lip that runs around the edges of the splitter, but there isn't a flat bottom, to speak.
Whether that matters, I don't know? I went with the EOS and have placed to layers of Slip-lo on it to try and protect the front lip from damage when rubbing on concrete, etc. (the front lip is all that can really drag, since there isn't any material on the bottom to drag).
Quality, paint, are subjective. I find the EOS to be very nicely finished (I have Carbon Flash splitter, side skirts and rear spoiler). I shopped them against ACS components but decided to go with the lower priced components.
Old Oct 4, 2023 | 04:12 PM
I installed a stage 1 splitter on my 2014. It is an OEM one and of course fit was excellent. If you go with a higher stage style splitter, ACS or C7 Carbon would be very good choices. EOS should also be considered, as they would offer a good product at a lower price.
Old Oct 4, 2023 | 06:07 PM
Catfish4818's Avatar
Catfish4818
No, you got a scratch AND you got rabbit stew!
Old Oct 4, 2023 | 06:13 PM
Travlee's Avatar
Travlee
The next day I didn't see rabbit pancake in the road, guess I yeeted him back in the grass somewhere
Old Oct 5, 2023 | 12:51 AM
paulam's Avatar
paulam
Cruising
thanks I will check C7 Carbon
Old Oct 5, 2023 | 12:53 AM
paulam's Avatar
paulam
Cruising
thanks I will check out EOS
Old Oct 5, 2023 | 12:54 AM
paulam's Avatar
paulam
Cruising
you and me both
Old Oct 5, 2023 | 12:59 AM
paulam's Avatar
paulam
Cruising
thanks
Old Oct 5, 2023 | 01:04 AM
paulam's Avatar
paulam
Cruising
thanks ok excuse my ignorance but what is stage 1 stage 2 etc?
Old Oct 5, 2023 | 02:05 AM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
https://www.corvetteforum.com/forums...-2-or-3-a.html
Old Oct 5, 2023 | 06:38 AM
C5Dan's Avatar
C5Dan
ACS was my choice, once I got my head around the rockers and how they fit. The customer service is outstanding and the products were flawless.
To Splitters
Old Oct 5, 2023 | 10:31 AM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
It was an easy decision for me. The quality and fitment of the EOS aero components are more than acceptable if your primary reason for the splitter is appearance. Especially since the ACS splitter is more than 2-times the cost ($897 vs $370). I have installed EOS's stage 2 Z06 spoiler, stage 3 side skirts, splitter w/ stage 2 winglets and the Z06 front grill. All looked great (Carbon Flash), as well as fit and installed with no issues.
If you are buying the aero components because you primarily high speed track your Corvette, then I would probably go with the ACS (or OEM) splitter. For normal driving, with an occasional high speed run, the EOS components are more than acceptable.
Old Oct 5, 2023 | 12:20 PM
paulam's Avatar
paulam
Cruising
thanks
ACS looks good but the price if I have it right was $1050 where as the C7 Carbon is $545.
I know you get what you pay for but can there be that much difference?
Old Oct 5, 2023 | 12:23 PM
paulam's Avatar
paulam
Cruising
thanks - just for looks
