Battery - dead
It’s a good thing that I remembered where the Manual Door Latch was located, because a security warning showed up on the driver display and the electronic door switch was inoperable.
About a week ago the battery gave a little hint that it was failing. On my return trip from a local store, during the final restart of the engine, it turned over a little slower than normal. Upon returning home I hooked up the battery tender, but, as we all know, the battery tender is not a charger. And it cannot overcome a failed or failing battery.
This happened to me in the past a number of times and the solution has always been a battery replacement. So I'll be on the hunt for a new battery soon.. Perhaps the only replacement battery should be OEM?
I gave some thought to AGM, but I've not had good luck with them in the past. In the end I chose OEM.
I'd be lying if I said it was easy. It was not. But it is doable for most guys with tools, strength and patience. THE BATTERY IS HEAVY!!!
A final note: I purchased one of those battery carrying straps. The strap did not fit well and came loose two times while I was trying to pull the battery. Purchasing the strap was a total waste of time and money.
Photo1 – Old Battery – the photo shows the Date Code, the Static Battery Voltage taken from the Harbor Freight load tester, and the location of the unused Vent Port with a White Vent Plug installed.
Photo2 – Load Tester - This photo shows battery voltage under a load condition. The load tester confirms the old battery is toast with a little less that 8 volts under load.
Photo3 – The Battery Well - In this photo everything is shoved out of the way. The space is deep and very limited.
I had a difficult time removing the battery because I could not get a hand under it to make the lift. Also, the carpet on the upper side of the photo (passenger side) prevented the battery from lifting straight up and out. I was finally able to flip the battery to a lengthwise vertical position, negative side down. This allowed better leverage to remove the battery.
-- I feel bad that I forgot to take the money shot of the battery in a vertical position - oh well, perhaps next time --
Photo4 – All done, everything reassembled but the Positive Cover Shield. A final check shows the little ground cable is attached to the main ground cable, and all cables are tight. The Vent Port tubing is installed.
For reinstall, the battery did have to go in vertically and then roll down to it's normal position. There are videos of guys pulling the battery straight out, but this way did not work for me.
Photo5- A vent plug is attached to the Positive Battery Shipping Shield. Don't forget to install the vent plug into the open Positive side Vent Port before dropping the new battery in place. You can install the plug afterwards without removing the battery (with tweezers and good eye sight), but it is better to do it first.
Did the[GM] ever try to change it themselves? I think not. A strap - turn it on the side - undo many extra bolts/nuts - remove padding === yikes!!!
