Proclip Question
Old Dec 17, 2023 | 01:31 PM
KnightmareCS's Avatar
KnightmareCS
Originally Posted by aadadams
That is not how it is supposed to be installed. the bottom should be wedged between the outer and inner handle. It appears your is sitting on top...
Originally Posted by Carvin
Looks like it is not snapped down.
Looks like that is the core issue. I didn't realize the handle was two pieces, I thought it was a single piece and wedging between would split the seam. Will correct. Also release the 'top' part can be pushed in a little more.
Thanks folks!
Originally Posted by westsdad
I pulled off the passenger side rectangular trim that is at the top of the boomerang shaped trim using a trim removal tool, installed the Pro Clip, and then reinstalled the trim piece. Makes it a lot easier especially when using the 3M adhesive tape on the Pro Clip.
What 3M tape??
Old Dec 17, 2023 | 02:12 PM
aadadams's Avatar
aadadams
I think you should read the installation instructions, then reinstall accordingly. The tape you asked about is underneath the top of the adapter. It comes with a protective cover that is to be removed before installation.
Old Dec 17, 2023 | 03:12 PM
KnightmareCS
I had the printed instructions it came with. The online version is much clearer. I'll redo install.
I didn't see mention of the tape in the instructions below.
http://docs.proclipusa.com/instructions/855034
Old Dec 17, 2023 | 03:27 PM
aadadams's Avatar
aadadams
In fairness, I haven't read the instructions in years. I see the mount point and I'm off to the races. I've been using ProClip for what seems like decades. Assumed it was in there... I am confident that when it is installed correctly, you'll be happy with it and the movement that you observed will be gone.
Old Dec 20, 2023 | 11:15 AM
SounderMN's Avatar
SounderMN
Mine did not pop off or slide under normal use. But, if I tried to adjust the phone position, it would sometimes pop out. I put a zip tie around it, and no more issues.
Old Dec 25, 2023 | 10:19 AM
Racer1735's Avatar
Racer1735
I have a 7-speed and bought the extension, but ended up not using it. Found that the phone was far enough over to not be a hindrance when shifting.
Also, when I installed mine, I fit the 'hook' (finger?) into the gap in my grab handle, then pressed the remainder of the mount over the top of the handle. Snapped right in and didn't seem to scratch anything. Fits solid!
Old Dec 25, 2023 | 10:36 AM
cuspid's Avatar
cuspid
Thought so
