Decklid
Old Dec 4, 2023 | 07:09 PM
Texan79423's Avatar
Texan79423
Default Decklid
What make the deck lid pop open mine hesitates or it pops releases but often does not rise?
Popular Reply
Dec 5, 2023, 08:26 AM
Maxpowers's Avatar
Maxpowers
A simple first step is to lube the seals. They can stick. I use silicone spray.
Old Dec 4, 2023 | 07:30 PM
Flattman's Avatar
Flattman
I noticed mine didn't pop up as much as usual last weekend but I'm blaming it on cooler temperatures. I know the gas struts on hoods and decklids don't seem to be as pressurized in cold versus hot - kind of like tire pressures but obviously more extreme.
Old Dec 4, 2023 | 08:20 PM
Trebor's Avatar
Trebor
I had a similar problem with my C6 convertible. I wrote the following thread in 2018. There is a commercial grade trunk popper, but, I made my own.
https://www.corvetteforum.com/forums...nk-popper.html
Old Dec 4, 2023 | 08:23 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
I'm having issues right now with the colder weather. I usually have to pop it twice
Old Dec 4, 2023 | 09:32 PM
bankers1's Avatar
bankers1
The older the car and the colder the temp seem to be killers for mine. I'm ready to carry an interior body tool in the pass. area to "Help" pop it high enough for a finger toget in.
How much are new struts, how hard to install, and any aftermarket available. It is getting tirering on a $ 95,000. 3LT to have to do this. In the coldest weather any of my BMW or MB would open right up. GM sucks.
Old Dec 5, 2023 | 06:41 AM
Texan79423's Avatar
Texan79423
OK lets back up here. Is it the struts pressure that lifts the deck or is there something else that pops it up?
Old Dec 5, 2023 | 08:26 AM
Maxpowers's Avatar
Maxpowers
Old Dec 5, 2023 | 11:35 AM
Flattman's Avatar
Flattman
Looked at AllData and I'm not able to see any inner workings of the latch or adjustments for what challenges you're having - just complete latch replacement and/or rear hatch alignment. And there is no mention of an internal spring or similar, just mechanical pieces such as "prawl, ratchet, and sector switches". I know that doesn't help you much, but in my experience when something with gas struts starts acting up, it's often those struts that are on their way out.
Also, did not see any TSB's on the rear latch other than manual release problems with 2016 and 2017 models that would show a fault or be mechanically inoperable.
Old Dec 5, 2023 | 04:59 PM
Texan79423's Avatar
Texan79423
Max power nailed it. Cleaned the seals and lubed with 303 works like new. Guess it dried up sitting in the sun on the lot. Big thank Max!!
To Decklid
