Where could I find the the.most commonly reported issues on 2015 c7 corvettes?
What parts are likely to fail and when, etc.. In the past on older vettes and cameras I know water pumps go out around 50k or so miles...
Is there an faq for this?
A simple problem that seems to occur often is a belt tensioner failure.
The early C7 generation belt tensioner had problems failing earlier than most would expect. It was was reengineered by GM and I believe it to be a much better tensioner. Time will be the judge on this one.
