C7 coolant flush
Manual calls for only Drain and Fill at 5 years however, in reading a bunch of posts I would say 75% of the people are doing Flush and Fills at 5 years. I plan on doing Drain and Fill as per manual (unless when doing the Drain and Fill I see "crap/crud or really bad coloring. If that happens then I would do a flush and fill)
If true, that would give you the benefits of multiple drain/refill cycles but much less hassle. I didn't ask how their price for the service compares to multiple drain/refill.
I still smile when i think about the days riding my bike to the library to photocopy Chilton manual pages for my 1979 Chevette.
Aha! I remember the days of the old Chilton books. Lots of great information inside of them. I had a 1978 Chevette and my mother owned a 1980. Seemingly, that was my first 'Vette - and was obviously not the best kind of 'Vette that one could own. LOL!!
Regarding the radiator flush, just use the Ranger method. Drain it all out and refill with tap water (some use distilled water, but you're not leaving it in there very long). Repeat the process three times OR until you are draining at just water with no visible coolant. Then fill it with the 50/50 premix (no need to worry about adding the proper amount of water). Run it until it is hot, then keep adding until it is full. Use the turkey baster strategy to drain out the overflow reservoir too. When you add the fresh pre-mixed coolant, don't forget the overflow reservoir. I never did it on my 'Vette because I sold it before I had the chance. The "Ranger" method worked fine on other vehicles.
It's important to use the proper coolant. In the case of the Corvette, it's likely the Dexcool stuff. With our Mazda, it took a different type formulated for Asian cars. A local shop wanted $249 to do a flush on our Mazda CX-30. I bought two gallons of pre-mixed coolant for $20 at Walmart and did it myself. The Corvette might be a bit trickier, though.
For those of you who got your coolant done along with brake fluid, transmission and differential oil, that was probably a wise idea. Make it worth the trip!
It's especially tricky when the dealers are using language like..."exchanged coolant fluid" or other ambiguous language which does not specifically say drain and fill or flush and fill on the customer invoice/receipt?
Always a challenge when going to a dealership for maintenance.
Even more interesting is that I believe their own shop manual calls to do a drain and fill and only do a flush and fill if the drained coolant is not translucent or is brown in color (or something to that nature).
Here is what is not as tricky. Ask the important questions like "Labor Rate", "Flat rate time", itemized parts list and cost and what the misc charges are. Under warrant, not my problem. Out of warranty and I'm paying, I demand those answers before employing them. If I am paying, I am not listening to your crap about how much the final charge is. I have told many of the appointment clerks or service advisors who quote me the total price and don't want to tell me what I want to know "I have college edumakashun. I can add, subtract, multiply and divide. I can get the total bill or an approximation if you give me the components of the bill. I don't know how to reverse engineer the components with the total alone.". When you tell me the triple flush is a great deal at $600, I can tell you that at $13 a quart and $200 an hour labor and the job calls for 2,8 hours, you aren't doing it as per procedure.
It is a challenge everywhere if you don't ask the right questions and expect it to be done right. People want to find a good place and expect every tech to be as good, knowledge wise and as good work ethic wise. Not happening. Weed out the bad ones and find the good ones.
What is the cost difference? If it isn't a lot, why bother? The flush is more thorough in that it cleans out more old coolant than must drain and fill.
