Found O-Ring under shift boot
Old Sep 2, 2024 | 11:25 AM
DHBWA's Avatar
DHBWA
Default Found O-Ring under shift boot
Previous owner had the shift boot off as it had slid down slightly. I figured I might as well check it out. Finally got the chrome plastic ring to rotate and slip
down which allowed me to remove the shift ****.
Lo and behold down on the shifter there was a o-ring doing nothing.
Any idea where it belongs??
Old Sep 2, 2024 | 12:00 PM
Zjoe6's Avatar
Zjoe6
I believe that belongs inside the top of the boot if there isn't one there. I'll post a pic. The staple shown in the pic is only on 2015 or 2016 I believe. Not sure how the newer ones are done. I also just bought a car that the boot won't stay up, but the o-ring is in the top of the boot. Maybe it's missing the staple? I'm still working on that. Some people have removed the boot plate, turned it inside-out and wrapped a wire around it or put a little zip tie there. Then flip it back inside-in. Re-assemble.
Old Sep 2, 2024 | 01:21 PM
DHBWA's Avatar
DHBWA
Just like mine and same condition….
Mine is a 2014 and the staples are there, such as it is.
Thanks!
Old Sep 2, 2024 | 08:32 PM
Zjoe6 - thanks for posting the pic.
Old Sep 3, 2024 | 08:09 AM
Zjoe6's Avatar
Zjoe6
Anytime Jack. I actually found it here on an old thread and thought I'd share it. It's a great pic whoever originally took it (I think JerryU).
http://netwelding.com/Shift_Knob.pdf
Found above in this thread.
https://www.corvetteforum.com/forums...-down-pic.html
To Found O-Ring under shift boot
