Blind Spot Solution?
Old Sep 4, 2024 | 10:06 PM
George_L's Avatar
George_L
Originally Posted by Skid Row Joe
Are the heating elements in the 2 & 3LT C7 mirrors still functional, after mirror application is applied?
the Paragon mirrors are replacements and maintain the heating capability. They do lose the dimming feature.
Old Sep 5, 2024 | 01:13 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I adjust the mirrors in the suggested manor and put the top down.. it works really well.
Old Sep 6, 2024 | 03:24 PM
Avanti's Avatar
Avanti
I just use the little black-framed round stick-on from the parts stores. With a black car they look okay and work great... plus, price and "installation" can't be beat!
Old Sep 6, 2024 | 08:48 PM
BluRace's Avatar
BluRace
i had the Sandyeggo Aspherical mirror stick on. Hated it.
Replaced it with the Wide Angle Paragon mirror replacement.
Love it
Old Sep 6, 2024 | 09:04 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Love it
Can you please explain the difference, both in design and how they work in real life?
Old Sep 6, 2024 | 09:32 PM
BluRace's Avatar
BluRace
i found the Sandyeggo Aspherical Mirror to be soft focus and dim,
i considered it to be dangerous
and
due to the added weight of the "Stick On" application
the mirror never properly went to its "Memory" Position,
so i had to adjust it everytime i started the car
the Wide Angle Replacement Mirror is sharp and clear,
i defy anyone to notice the difference between it and OEM
without driving the car
AND
the "Memory" now works again.
Old Sep 6, 2024 | 09:37 PM
Gearhead Jim
St. Jude Donor '13
and
AND
Beyond the "soft focus and dim" thing, what else is different between the two mirrors?
Or to ask the question a different way, if the Sandyeggo mirrors were sharper focus and brighter, would there still be other differences like field of view or something else?
Old Sep 7, 2024 | 04:02 AM
inspectorudy's Avatar
inspectorudy
I have the Sandyeggo ones and they are great. I have no idea what soft focus means or dim. They are just like the OEM mirrors except they have a slight curve in them for a wider view. It takes zero time to adjust to them and they really help with the blind spot. The removal is with a monofilament line and a hair dryer. No tools are required to put them on and once on there have been no issues.
Old Sep 7, 2024 | 07:56 AM
Squeaky Wheel's Avatar
Squeaky Wheel
I’m debating switching to one of these mirrors. Leaning toward the Sandyeggo design due to the simplicity of installation. Would be nice to retain the heated function with the Paragon but I fear breaking something (either the motor or mirror itself) popping off the OEM mirror. Looks like the retaining clips on the back of it are just plastic and I had bad luck with breaking those clips on a similar powered mirror replacement on a Chevy Suburban.
Old Sep 7, 2024 | 03:24 PM
BluRace's Avatar
BluRace
According to the Sandyeggo website
The C7 driver's side Panoramic Door Mirror is designed with two reflective stages. Starting closest to the door and continuing outboard, there is a small but increasing amount of convex curvature. This is to provide additional view angle without causing excessive distortion. This is the primary viewing area and provides overall blind spot reduction.
At a certain point outboard the amount of curvature is increased exponentially. This was done to capture as much of the surrounding view as possible. The trade-off is greater image distortion in this portion of the mirror.
The increased curvature and the and distortion i found to be unsafe.
It was easy to remove with monofilament line and throw it away.
Old Sep 7, 2024 | 04:25 PM
C-141 driver's Avatar
C-141 driver
The increased curvature and distortion i found to be unsafe.
Was this the Sandyeggo mirror?
Old Sep 7, 2024 | 04:39 PM
BluRace's Avatar
BluRace
yes to Sandyeggo mirror
did not work for me
Old Sep 7, 2024 | 08:19 PM
  #33
CraigStu's Avatar
CraigStu
did not work for me
Maybe you could rephrase that.
Old Sep 7, 2024 | 09:06 PM
  #34
BluRace's Avatar
BluRace
yes,
i did not like the Sandyeggo Mirror,
i found it to be unsafe.
it did not work well for me.
Old Sep 7, 2024 | 09:30 PM
  #35
aklim's Avatar
aklim
Old Sep 7, 2024 | 09:45 PM
  #36
aklim's Avatar
aklim
Instead of screwing around with mirrors, if you are fine with not having the dimming mirror, why not use THIS? Why would I want a mirror when a sensor will do it better?
Old Sep 7, 2024 | 10:23 PM
  #37
DHBWA's Avatar
DHBWA
Great item but two issues..
*some guys don’t want to even replace the actual mirror part let alone disassemble the door to install these.
*Unless these are wider you just gave up some mirror for the turn signal.
BTW- where is there a sensor that alerts the driver of someone in the blind spot?
After driving mine and adjusting the mirrors properly I just don’t have a large blind spot. The previous owner installed a little round spot mirror on the drivers side but ignoring it there just isn’t a huge issue…To me….
To Blind Spot Solution?
Old Sep 7, 2024 | 10:41 PM
  #38
aklim's Avatar
aklim
Wrong link. THIS is the right one.
Correct but this should zero out the blind spot, just in case.
Old Sep 8, 2024 | 10:00 PM
  #39
Woodson's Avatar
Woodson
A solution looking for a problem.
Old Sep 9, 2024 | 12:17 AM
  #40
Vette Jockey
Roadster Madness. 😠
I found putting the top down works wonders!
