Audio upgrade
Old Jan 3, 2025 | 11:46 AM
Paulcapitanio's Avatar
Paulcapitanio
Cruising
Default Audio upgrade
Looking to upgrade my sound system in my 2014 Stingray. Anyone have recommendations?
Old Jan 3, 2025 | 11:56 AM
ChodaBoy's Avatar
ChodaBoy
More details needed.. Trying to add speakers or replace existing, or both? What kind of budget to you have? Are you wanting to sacrifice your rear cargo area? Are you going to install/tune yourself or going to have a shop do it?
Old Jan 3, 2025 | 12:02 PM
Paulcapitanio
Cruising
I think I want to upgrade all the speakers but not disrupt the stock look of the interior. Would not be against using a low profile subwoofer box on the rear floor. From what I understand, I need to purchase an interface module and its only made by PAC? Would like to do the work myself but probably should get some professional help. My daily drivers are always new, latest vehicles and the sound system in the 2014 Corvette leaves a lot to be desired. I am hoping to keep the budget around $3000/$3500
Old Jan 3, 2025 | 01:17 PM
NortonCO's Avatar
NortonCO
Depending on your specific goals, these threads may be of interest...
- https://www.corvetteforum.com/forums...we-can-do.html
- https://www.corvetteforum.com/forums...subwoofer.html
- https://www.corvetteforum.com/forums...mendation.html
- https://www.corvetteforum.com/forums...e-project.html
​​​​​​​- https://www.corvetteforum.com/forums...nexpected.html
Old Jan 3, 2025 | 02:19 PM
miami08VETTE's Avatar
miami08VETTE
The 5th link above is my project to tackle same thing you're looking for. All the links are loaded with good info. I list the speakers I used. It's a speaker upgrade only, kept OE amplified woofer in back. Generally, not difficult to do just time consuming. Will take some cutting/splicing of the end connectors. Results were night and day in my opinion. No regrets! Crutchfield is a good source for speakers and misc parts and tools you'll need to make life easier. Good luck...
Old Jan 4, 2025 | 11:55 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
On our 2017 2LT;
Sitting still with the engine idling, the sound system is great.
Driving 30 mph it's uh, "ok".
Driving 60 mph, it's crummy.
Driving 90 mph, it's just noise and no music.
Reducing ambient noise is not cheap or easy, but that's what I'd do first.
Old Jan 7, 2025 | 11:41 AM
orca1946's Avatar
orca1946
And then add "sound deadening" to entire hatch area while you are at it!
Old Jan 7, 2025 | 01:22 PM
miami08VETTE
Just add sound deadening material as stated above. You'll have everything opened up so that would be the time to do it.
To Audio upgrade
