Cost for system programming update?
Old Feb 24, 2025 | 10:56 PM
madison_m's Avatar
madison_m
Navigator
Default Cost for system programming update?
Hi guys. I need to take my 2018 C7 Z51 to the dealership for some work (including black infotainment ugggg.) The dealer says it's been a long time since the software / firmware whatever has been updated. They want to charge $300 for that. Is that price real? (California, Orange County price?)
Thanks!
Old Feb 25, 2025 | 12:10 AM
76-Vetteman's Avatar
76-Vetteman
Is this a required system programming update?
Old Feb 25, 2025 | 12:15 AM
I guess it depends on what the labor charge per hour is. around here that would be about 2.25 hours labor to do the job.
Old Feb 25, 2025 | 02:13 AM
madison_m's Avatar
madison_m
Navigator
They say it is required before they will begin diagnosis of the blank infotainment system screen. They also say there is a “possibility” it may resolve that problem….
Old Feb 25, 2025 | 04:57 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Corvette Mike is in Anaheim. The owner is very knowledgeable about all generation's. Give them a call.
https://www.google.com/search?q=corv...firefox-b-1-m#
Old Feb 25, 2025 | 08:37 AM
76-Vetteman
Ah yes, the blank infotainment screen.
Best of luck with the solution. A good dealer should be able to sort it out.
Old Feb 25, 2025 | 08:48 AM
Zjoe6's Avatar
Zjoe6
Sounds like they're shooting darts. I'd try another dealer with better technical skills. What if it's just a bad infotainment screen? They need to determine the root cause.
Old Feb 25, 2025 | 08:53 AM
76-Vetteman
As I recall there was a cable problem with the infotainment screen where the cable failed and the screen would become jammed. I'm wondering if this is related?
Old Feb 25, 2025 | 09:00 AM
Zjoe6's Avatar
Zjoe6
Sure could be.
In the third link below the OP said just resetting the 12V power might have fixed it. It could be many things.
https://www.corvetteforum.com/forums...een-reset.html
https://www.corvetteforum.com/forums...nt-screen.html
https://www.corvetteforum.com/forums...-no-sound.html
Old Feb 25, 2025 | 12:11 PM
madison_m's Avatar
madison_m
Navigator
Thank you so much for the feedback. I've tried the reset, checked the cables as best I can. The service tech said something about the MOST system having multiple components and they cannot necessarily diagnose it correctly until they get that working. I'll keep them from running wild on this thing.
I love the C7, virtually no problems with it except for this. I haven't used the cool up/down secret compartment thing more than a few times, even it was the coolness factor that pushed me over the edge and selling the C6.
Thank you again!
Old Feb 25, 2025 | 12:32 PM
Zjoe6's Avatar
Zjoe6
I'm sure you tried this, but try raising and lowering the screen a few times to see if that makes any improvement. There's probably a limit switch that turns the screen on or off depending if the door is down or up.
Old Feb 25, 2025 | 01:17 PM
kodpkd's Avatar
kodpkd
The last time an Ahole said it would take a special technician an hour to program my car, I said, no thank you. I took the car home, did some research, and did it my self in 5 minutes. It wasn't a Corvette. Do a little more research. The other suggestions are great.
Old Mar 6, 2025 | 10:32 PM
aristarchuscom's Avatar
aristarchuscom
Thanks!
[After re-reading I miss understood what "programming" you are talking about"] Referring here with this note to the suspension flash program that's 300 bucks and is a part number from GM] It was one of the first things I did once I found out about it for my 2018 Grand Sport. Yes it's 300 bucks and there's a GM part number for it. Make sure you get the part number on the receipt for your records. It's not a part it's flash code for your suspension. Night and day performance on the stock GrandSport wheels, and now I run Vossen HP5's because the stock ones bent badly, and it runs on rails. Get it, money well spent. While you have it there, get the rear dif fluid changed and if you have an Auto 8 speed I just got the Triple Flush and tranny replace per the tech bulletin (that was 1600.00), pay to play brother. Vroom.
Old Mar 6, 2025 | 11:14 PM
aklim's Avatar
aklim
Thanks!
Forget the $300. If you tell me 3 things, I can estimate the price. Number of hours, cost of materials and labor rate. Number of hours is important if you want to see if the guy is padding the bill or cutting out stuff. You can look at the flat rate hours for the job and that will tell you if he is skimping on something or just adding hours. Labor rate? Nothing you can do about that except see if it is reasonable for your area. So before you ask if the price is real, ask how many labor hours are expended and someone with a labor rate guide can tell you.
Old Mar 7, 2025 | 08:40 AM
kodpkd's Avatar
kodpkd
My opinion,,,,, $300, look for another estimate. I had a different car, purchased an additional key fob, the dealer wanted $150 to program it, I did some research and it took me 5 minutes to do myself.
Old Mar 7, 2025 | 09:34 AM
aklim's Avatar
aklim
Based on what? OP still needs to find out how long it will take, AKA flat rate time before you can determine if it is excessive or not.
I've had body shops that would be able to beat my best quote consistently. Works if you are stupid enough to just look at the last line. You tear that quote apart and the paint price is about the same but they cut the amount of hours worked. As we all know, any idiot can shoot paint. Prep work determines whether the paint sticks on 5 years from today like it does on day 1 or whether it peels off.
Old Mar 7, 2025 | 11:24 AM
kodpkd's Avatar
kodpkd
My other question. Are the 2019 corvettes still being updated? Didn't they suspend all updates on the C7's?
Old Mar 7, 2025 | 11:41 AM
IA-SteveB's Avatar
IA-SteveB
Thank you again!
Sometimes honking the horn will bring the screen back to life, but only for a short time. That just helps confirm it could be something other than the screen itself. My 2014 had a flickering screen at first and then decided to go black. I decided to tear the dash down so I could get to the cabling the proper way and found them to be shredded and loose from the door being used too many times. I bought a
new cable new cable
from Amazon for $6, and the problem has not come back since. It took a long time, but I only pay myself $1.50/hr, so it was much cheaper than the dealership. You can't really check the cables very well from the little access port in the footwell. You can see them, but not whether they are loose or frayed. In the picture below, the triangle cover isn't attached correctly.
Old Mar 7, 2025 | 12:32 PM
aklim's Avatar
aklim
They might not have anything new but you may also have a car that has not been updated yet.
To Cost for system programming update?
