Key help
Old Mar 9, 2025 | 09:10 PM
Augsten's Avatar
Augsten
Default Key help
Can you help me determine which key I should buy?
corvette 2019
Old Mar 9, 2025 | 09:16 PM
Augsten's Avatar
Augsten
I would like to buy this one and I don't know if it's the right one
Old Mar 10, 2025 | 07:45 AM
OStebbins's Avatar
OStebbins
2nd Gear
For your 2019 Corvette, you'll need a key fob that's compatible with the model and year. It's best to go through a dealer or a trusted locksmith to ensure compatibility. You can also check online for replacement options. If you're into cars and tech, you might find marketplace app development company useful for exploring digital solutions in the auto space.
Old Mar 10, 2025 | 09:26 AM
Zjoe6's Avatar
Zjoe6
It's in the below thread post #3 which I copied and pasted below. I don't know from your VIN but you can decide from the list. The one you listed in post #2 is the 2016-2019, coupe, automatic trans, w/ Remote Start.
https://www.corvetteforum.com/forums...-question.html
4 button TRANSMITTER W/O REMOTE START Manual 14/15 22779879 16/19 23465950
5 button TRANSMITTER W/REMOTE START Automatic 14/15 22779880 16/19 23465951
5 button TRANSMITTER W/O REMOTE START Manual Convertible 14/15 22816265 16/19 23465954
6 button TRANSMITTER W/REMOTE START Automatic Convertible 14/15 22816266 16/19 23465955
NOTE: Part numbers can change! Always verify part numbers with your dealer!!
Old Mar 10, 2025 | 11:26 AM
Augsten's Avatar
Augsten
[QUOTE=OStebbins;1608631726]Para tu Corvette 2019, necesitarás un llavero que sea compatible con el modelo y el año. Lo mejor es que lo consultes con un concesionario o un cerrajero de confianza para asegurarte de que sea compatible. También puedes consultar en línea las opciones de reemplazo.[/QUOTE
]Here in my country we don't have a good dealer for Corvette
Old Mar 10, 2025 | 11:27 AM
Augsten's Avatar
Augsten
[QUOTE=Zjoe6;1608631938]Está en la publicación n.° 3 del hilo que aparece a continuación, que copié y pegué a continuación. No lo sé por tu VIN, pero puedes decidirlo a partir de la lista. El que mencionaste en la publicación n.° 2 es el cupé del año 2016 al 2019, con transmisión automática y arranque remoto. Español:
https://www.corvetteforum.com/forums/c7-general-discussion/4557140-key-fob-question.html
TRANSMISOR de 4 botones SIN ARRANQUE REMOTO Manual 14/15 22779879 16/19 23465950
TRANSMISOR de 5 botones CON ARRANQUE REMOTO Automático 14/15 22779880 16/19 23465951
TRANSMISOR de 5 botones SIN ARRANQUE REMOTO Manual Convertible 14/15 22816265 16/19 23465954
TRANSMISOR de 6 botones CON ARRANQUE REMOTO Automático Convertible 14/15 22816266 16/19 23465955
NOTA: ¡Los números de pieza pueden cambiar! ¡Siempre verifique los números de pieza con su distribuidor!
[/CITA
]Very kind, in theory it is compatible with my car. It is a 2019 Corvette with automatic transmission
Old Mar 10, 2025 | 01:04 PM
westsdad's Avatar
westsdad
Be sure to get the one for the Coupe or the Convertible depending on what your 2019 C7 A8 is.
You'll need the following for programming the new key fob, and will need to do the long programming since you only have one of the two key fobs that are programmed in.
https://www.corvetteforum.com/forums...s-and-rke.html
Old Mar 10, 2025 | 08:20 PM
aklim's Avatar
aklim
I would wipe both keys and start over with the long process.
Old Mar 11, 2025 | 10:30 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I'd do that in the parking lot of the dealership, just in case something goes wrong and you can't get started afterward.
Those with more experience and talent might not bother.
Old Mar 11, 2025 | 11:04 AM
aklim's Avatar
aklim
Definitely. In my case, since it was paid for, I had the tech do it. Even with his experience doing it, he managed to brick the car and spent even more time doing it. Why would I even want to risk it when the seller is paying for it to be done.
If I had to DIY, I would set the appointment for say 1pm and try it at 10am. Cancel the appointment if I succeed and have them wheel it in if 8 don't.
Old Mar 11, 2025 | 12:29 PM
Augsten's Avatar
Augsten
One more question, can I buy a used key from eBay and program it to my Corvette? Or does it just have to be new?
Old Mar 11, 2025 | 01:04 PM
aklim's Avatar
aklim
You can ASSUMING it is the correct key. After all, when you wipe both keys, it will be assuming 2 new to the car keys. I would not want to use a used key but that's me.
Old Mar 11, 2025 | 05:29 PM
Gearhead Jim
St. Jude Donor '13
A C7 has both an electronic fob for unlock/start/etc, and a mechanical key to open the trunk if the electronics can't.
Any fob with the correct part number can be paired with an appropriate Corvette, unless something is wrong.
The mechanical key for the trunk is cut to the VIN on the car, they are not interchangeable unless you are unusually lucky.
Old Mar 11, 2025 | 05:35 PM
budgreen3564's Avatar
budgreen3564
Chevrolet dealer new fob and programming over $400
Old Mar 11, 2025 | 05:42 PM
Augsten's Avatar
Augsten
Exactly. That was my question. If I buy a used remote, without the key to open the trunk.
Old Mar 11, 2025 | 05:46 PM
aklim's Avatar
aklim
Tech took over an hour, so at $150 an hour, which is not the highest the labor rate can go, what do you expect?
Old Mar 11, 2025 | 05:53 PM
Augsten's Avatar
Augsten
I bought this now, I hope it helps me
To Key help
Old Mar 11, 2025 | 08:55 PM
westsdad's Avatar
westsdad
Reading the entire thread, it sounds like the OP doesn't have the "luxury" of having a GM dealer in their country.
Old Mar 11, 2025 | 11:13 PM
Augsten's Avatar
Augsten
Exactly, I mean there is a Chevrolet dealership but they didn't bring a Corvette.
Old Mar 12, 2025 | 09:59 AM
Gearhead Jim
St. Jude Donor '13
I suspect that the C7 keyless system is not too different from other Chevrolets. If they can program fobs for Chevys in general, I think they could do it on a 'vette.
