header review
Old Feb 11, 2026 | 08:30 AM
  #41
smitty2919's Avatar
smitty2919
Originally Posted by emfollin
Maybe you can confirm Smitty upon receipt of your headers but EOS stated their tubes are 16 gauge meaning 1/16” thickness or 1/8” in diameter. That means the OD of the connector tube at the slip joint is likely 3.125”. If you go with a lap band, you’ll want a 3” ID to 3.125” ID band. I did find one on Amazon. Most were 3” ID to 3.15” ID which likely would work but you’ll have a 0.0125” gap all way around.
You're overthinking this WAY too much....have you used a lap style band clamp and have you measured out 0.0125"? That is SO minor when it comes to exhaust pipe. Hell your pipe expand/contract more than that just driving the car.
Everything is sold as "nominals". A 3" slip fit joint will have the male pipe be ~3" OD while the female is flared to accept a ~3" OD pipe...what the exact ID/OD is on the pipe depends on the manufacturer and their tolerances/quality.
Old Feb 11, 2026 | 08:39 AM
  #42
emfollin's Avatar
emfollin
It’s bigger difference than you think. This joint might not have much play in it anyway so it might
not matter but my experience with bands on the xpipe to axle pipe connection required an exact match. Could have been any number of variables but that small gap I had in my connection allowed the axle pipes to slide out.
Old Feb 11, 2026 | 01:58 PM
  #43
9sec's Avatar
9sec
heres what my eos long tube headers welded in and eos catless midpipe wiuth npp oem mufflers sound like at 6100 rpm. headphones on loud!!!
957 rwhp so im going to guess that the headers flow pretty darn good!! sorry for the fuzzy video better video on my build thread
File Type: mov
Old Feb 11, 2026 | 03:08 PM
  #44
emfollin's Avatar
emfollin
Nice!
Old Feb 20, 2026 | 10:16 AM
  #45
smitty2919's Avatar
smitty2919
Headers ordered. Will get a bunch of photos when they arrive.
Old Feb 20, 2026 | 04:24 PM
  #46
9sec's Avatar
9sec
friend of mine just installed these on his car. there was a small hole where the slip fit piece and the header come together. a 2" band clamp solved the issue no leaks
Old Feb 20, 2026 | 06:12 PM
  #47
emfollin's Avatar
emfollin
LT1 or LT4? Curious how it responds on LT1.
Old Feb 20, 2026 | 11:57 PM
  #48
9sec's Avatar
9sec
lt4
Old Feb 23, 2026 | 04:58 PM
  #49
emfollin's Avatar
emfollin
@9sec i know you’re catless, What xpipe did your buddy use? I’m very concerned about going full catless. Getting high flows welded on my current xpipe starts to negate the price advantage of these headers. I’d consider going back to factory xpipe if it flows well enough with heads/cam.
Old Feb 23, 2026 | 05:50 PM
  #50
9sec's Avatar
9sec
he is also catless im n to sure what the brand is . I initially ran eos catless downpipes and catless mid pipe . prior toilet that I ran the oem mid pipe with the catless downpipes and flow didnt seem to suffer. the nice thing about the eos headers is if you dont like the full catless sound or smell then oem pipe bolts right up to them . same flanges as oem
Old Feb 23, 2026 | 06:02 PM
  #51
smitty2919's Avatar
smitty2919
My EOS headers are showing up tomorrow. This is my plan to run full catless and if it smells too bad to use the stock midpipe.
I may even be able to get some dyno runs done between the two midpipes as time goes on. Less than 10hp loss I don’t care if it kills the smell. I’ll make up for it going E85 lol
Old Feb 23, 2026 | 06:06 PM
  #52
emfollin's Avatar
emfollin
Agree 100%. Smell just isn’t worth it. Wife and kid will never ride with me if that was the case.
Old Feb 24, 2026 | 08:58 AM
  #53
smitty2919's Avatar
smitty2919
@9sec how much oil did you lose when popping off the dry sump lines? I don't plan on draining the oil since I don't need an oil change. Just being prepared for how much oil to catch.
FWIW, car has been sitting on a lift for couple weeks.
Old Feb 28, 2026 | 06:17 PM
  #54
emfollin's Avatar
emfollin
Did you get the headers Smitty?
Old Feb 28, 2026 | 06:21 PM
  #55
9sec's Avatar
9sec
you will lose it all. have to drain it to get the lines off and out of the way
Old Feb 28, 2026 | 06:59 PM
  #56
smitty2919's Avatar
smitty2919
I did but then had to go out of town. They look nice and have a merge spike.
Ahhh crap. I was hoping to lose only a little lol
Old Mar 1, 2026 | 03:24 PM
  #57
smitty2919's Avatar
smitty2919
@emfollin see post below:
https://www.corvetteforum.com/forums...er-review.html
To header review
Old Mar 1, 2026 | 03:31 PM
  #58
smitty2919's Avatar
smitty2919
@9sec in this picture below, was this with the header bolted up and the connection at the midpipe tight? Was there this "gap" there like the extensions needed to slide on the header more? But couldn't because it was tight to the midpipe? It's like the header needed about 1" more welded to it.
Old Mar 1, 2026 | 05:36 PM
  #59
9sec's Avatar
9sec
I saw this on mine as well. a 3" band clamp will cover it and keep fumes from coming in to the cabin but I opted to mark both pipes clamp it and have my welder cut out the expanded short piece and weld in a straight section. eliminates and chance of fumes and eliminates a set of clamps
Old Mar 1, 2026 | 05:43 PM
  #60
smitty2919's Avatar
smitty2919
Ahhh got ya, that was actually YOUR photo lol. I'll grab some 3" lap style band clamps and see how it seals.
