I leave my range device plugged in all the time. How well it prevents AFM failure is debatable.
It has a hypothesis but there is no way to prove it one way or the other. IIRC, manual cars also have had lifter failure so..... My Diablo I3 will do that, make the engine run a bit better (so some have said), firms up the shift and adjust the throttle tip in a bit. More expensive but does way more.
I installed my Range device one week after I took delivery of my 2019 GS on October 2, 2018. I leave it plugged in except when I have to take it to the dealership. I usually remove it about 2 days before my appointment. No issues and no V4.
Sounds like crap in V4 mode. And the time spent in V4 mode is torture for the tranny/torque converter and torque tube.
IDK about sound since I have mine set on Stealth Mode always but perhaps the issue isn't spending time in V4 mode as much as switching over because GM couldn't and/or wouldn't design a proper system?
With 4 cylinder disabled, it seems to drive better when locked into 8 cylinder (to me).
IIRC, I had to look to know before I shut it out by the ECM program. I wasn't ever sure if I could tell it without looking for it which meant a prejudice. I obviously couldn't do a blind test.
When I had it, I know for sure that when I hammered it, there was no issue. From what I see, it only engages when it is on light pedal or cruise and in both cases, I really don't care since it doesn't limit the power when I want it.
If the engine fails because of switching in and out of afm you will probably care. 🫥
I was run the car in the Manual mode and paddle shifting because I had the dreaded shutter. Once I had the trip flush done it correct the shutter, so I just drove it in the Auto mode, but I was worried about the AFM and wiping out a lifter and cam, so I bought the Range device. My son has less miles on his GMC Denali and it got his lifters and cam. Luckily, he has a full engine warranty, so it cost him nothing and they gave him a brand-new Denali to use. So I recommend getting one.
Any of the devices, Range, programming, etc, is only a theory, from what I see. I honestly have not seen any kind testing done that shows a significant reduction of the chance of failure. I still think the only way to fix it will be to change the lifters.
