LMR Dyno's C7 corvette!
Old Sep 27, 2013 | 04:39 PM
Late Model Racecraft's Avatar
Supporting Vendor
Default LMR Dyno's C7 corvette!
Initial Testing has begun. Even with our car still on the way we have found a way to begin some of our initial testing. Stay tuned for more updates!
Old Sep 27, 2013 | 04:44 PM
dvdhotboy's Avatar
dvdhotboy
no results come on.
Old Sep 27, 2013 | 04:50 PM
Supporting Vendor
Originally Posted by dvdhotboy
no results come on.
did you watch the video? Right at the 1:32 mark it shows the results...
Zee51Vert's Avatar
Zee51Vert
no results come on.
see the results at 1.32. Below par. All other tests so far dyno's above 400 rwhp
Old Sep 27, 2013 | 04:51 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Curious how that compares to stock LS3 and LS7 cars.
S.
Old Sep 27, 2013 | 04:53 PM
dvdhotboy's Avatar
dvdhotboy
my bad didn't know I had to pause it. thx bud
Slappy3243's Avatar
Slappy3243
Nice! I bet with engine break-in, there is more power to be had naturally.
Old Sep 27, 2013 | 05:54 PM
R W B's Avatar
R W B
LMR, in the video it looked like the LED lights in the headlight were pulsing. Do you know what that was from? I watched a few times, guess it could be a reflection of something but it was steady the whole time.
Watched it again and looks like the taillights are pulsing too?
Umm... The numbers I saw were 400whp 1st run and 402whp 2nd run. Technically that's over 400whp. Did I misread something lol?
Old Sep 27, 2013 | 05:57 PM
VIN666's Avatar
VIN666
LEDs look like they are pulsing on most cameras, because they are, but you can´t see it with the naked eye.
Old Sep 27, 2013 | 06:07 PM
PRE-Z06's Avatar
PRE-Z06
A dyno is a tuning tool, just because this one reads lower doesn't mean that the car isn't healthy or the numbers aren't accurate. It didn't sound like it was an auto nor could I see inside it, but I'd confirm that to make sure that wasn't why it dynoed lower.
The output of light from an LED is a certain frequency in hertz. Let's say it's 30 Hz from the LED and the camera recording it records at a common 24 frames per second. Every few frames recorded by the camera will not be in sync with the light source and thus a "blinking" occurs where the camera caught the LED in between cycles.
Old Sep 27, 2013 | 06:08 PM
PRE-Z06's Avatar
PRE-Z06
S.
That would be a good cool overlay!
Old Sep 27, 2013 | 06:31 PM
Dominic Toretto's Avatar
Dominic Toretto
No need to pause it, just watch it all the way through.
Could the front plate frame be hindering the intake?
-Alex
Old Sep 27, 2013 | 06:39 PM
tail_lights's Avatar
tail_lights
Hope it makes more than that after break in, especially for a manual.
Old Sep 27, 2013 | 06:47 PM
JoesC5's Avatar
JoesC5
Lingenfelter did that overlay(LS3/LT1/LS70 a few days ago in a different thread.
Old Sep 27, 2013 | 06:50 PM
JoesC5's Avatar
JoesC5
12% driveline loss is normal for the C6 manual and it is the same driveline as the C7. 460HP X 88% = 404.8 HP.
Old Sep 27, 2013 | 06:58 PM
JoesC5's Avatar
JoesC5
S.
I bet it would look like this comparison...
Old Sep 27, 2013 | 07:09 PM
OnPoint's Avatar
OnPoint
The Consigliere
What are your plans for it, OP?
To LMR Dyno's C7 corvette!
Old Sep 27, 2013 | 07:29 PM
Snorman's Avatar
Snorman
Yes, I saw that comparison a number of days ago.
I would like to see the same comparison using data from LMR on their dyno with an LT1, LS3 and LS7.
S.
Old Sep 27, 2013 | 07:32 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
That silver is bad ***!
Old Sep 27, 2013 | 07:33 PM
PRE-Z06's Avatar
PRE-Z06
I missed that, thanks for sharing below.
