C7 Weights and Specs
Old Jan 28, 2014 | 06:39 PM
LEAVINU's Avatar
LEAVINU
Originally Posted by Turbooo2u
Do most of the popular header options save weight would you know?
Thanx..
Most of the "off-road" style (i.e. no cats) definitely save weight on the C5/C6's so one would assume the same for the C7. I believe it's @25lbs minimum on those gens just for reference.
Old Jan 28, 2014 | 07:15 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Thanx..
I should know final weights on all of our header designs shortly, as they are going to be different.
Typically speaking 20-26 lbs weight savings isn't out of the question.
I know Akrapovic is working on an muffler system for the car but we are still months off on that.
Old Jan 28, 2014 | 09:24 PM
BERETTA's Avatar
BERETTA
Thanks for this info
I would like to add that a 3LT heated and cooled drivers side seat weighs 60lbs.
Old Jan 28, 2014 | 09:41 PM
Turbooo2u's Avatar
Turbooo2u
In GM official brochure, they site the best numbers from the Z51 model, but when it comes to curb weight, they site the lighter base model. Seems like the heaviest model is the 3LT Z51 at close to 3425.
That probably includes MSRC. I wish we could get the breakdown for models like a 1LT Z51 without MSRC.
Old Jan 28, 2014 | 09:43 PM
Turbooo2u's Avatar
Turbooo2u
Thank you for the info. That is quite a savings in weight. I'm looking at mid-length headers with hi-flo cats. That setup seems to be popular for some who don't want to re-tune the vehicle.
Old Feb 17, 2014 | 09:21 AM
Former Vendor
I'll try and update the thread as I go, and as we go further into the car too.
Old Feb 17, 2014 | 09:53 AM
ChucksZ06's Avatar
ChucksZ06
My car is a manual 1lt z51 and it weighed 3362 on my corner scales with 3/4 tank of fuel.
Old Feb 26, 2014 | 01:40 PM
Former Vendor
Nice...and not that far off corner weights either..
Old Feb 26, 2014 | 02:29 PM
Kracka's Avatar
Kracka
Impressive. Did you adjust the bolts to get those values or is that stock?
Old Feb 26, 2014 | 03:17 PM
JoesC5's Avatar
JoesC5
Appears to be 92 pounds heavier(with a full tank of gas, 3390) than what GM says is the curb weight of the base C7(3298).
Old Feb 26, 2014 | 03:58 PM
travisnd's Avatar
travisnd
Z51 has a lot more content than a base C7. The Z51 is a 3400lb car no matter how you slice it (with a full tank). Fuel is 6.6 lbs/gal.
Old Mar 10, 2015 | 05:00 PM
Former Vendor
Updated
Old Mar 10, 2015 | 10:34 PM
  #33
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I posted some OEM wheel specs in a thread a while back. Not sure if this will help to add to the collective good or not
https://www.corvetteforum.com/forums...to-thread.html
Old Apr 7, 2015 | 10:36 AM
  #34
Former Vendor
Keep it coming!
I'll try and update it as I go along with the tear downs on the cars.
Old Apr 10, 2015 | 08:39 AM
  #35
meyerweb's Avatar
meyerweb
Has anyone ever seen wheel weights for the stock non-Z51 wheels? The link above has to be wheels and tires.
Old Apr 10, 2015 | 09:10 AM
  #36
Higgs Boson's Avatar
Higgs Boson
tirerack.com lists tire weights, just subtract and boom - wheel weights.
Old Apr 10, 2015 | 12:07 PM
  #37
GTB/ZR-1's Avatar
GTB/ZR-1
Agreed... My non-Mag Ride M7 1LT Z51 with Comp seats weighed 3317 with ~1/4 tank. I calculated that it would be a hair over 3400 with a topped-off tank.
No corner-weighting done, yet.
image by gtbzr1, on Flickr
To C7 Weights and Specs
Old Apr 10, 2015 | 02:42 PM
  #38
descartesfool's Avatar
descartesfool
My completely stock 2014 C7 Z51 1LT M7 with mag dampers full of fuel weighs 3411 lbs.
Corner weights scales leveled within 1/16":
LF = 812
RF = 890
LR = 882
RR = 827
Front % = 49.9%
Left % = 49.7%
Cross (LF+RR)/3411 = 48%
Old Apr 10, 2015 | 02:43 PM
  #39
tyho's Avatar
tyho
C7 of Year Finalist (performance mods) 2019
My mission in life is to drop 100 lbs from the car. So far ARH mid-length, 24 lbs, Halltech all carbon cai, 8 lbs., Carbon plenum and rail covers, 2 lbs, Braille light weight battery, 18 lbs., removed emblems, stingrays, CORVETTE on the rear bumper 4 oz. changing to B & B bullets, ??? yet. Installed GT MAT sound deadening 10 lbs added. Net weight loss is about 42 lbs so far. Eventually I will change the rotors and tires to non runflats. This should drop about 12-14 lbs. per wheel.
Old Apr 10, 2015 | 09:34 PM
  #40
meyerweb's Avatar
meyerweb
I should have thought of that.......
Thanks.
