Fluid under right front
Old Oct 6, 2013 | 05:00 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default Fluid under right front
Red in color, possible power steering fluid?
Old Oct 6, 2013 | 05:33 PM
SimpleC6's Avatar
SimpleC6
Smell it?
Old Oct 6, 2013 | 05:47 PM
Unreal's Avatar
Unreal
Electric power steering so no fluid.
Old Oct 6, 2013 | 06:01 PM
schilitj's Avatar
schilitj
Red, oily, did not smell it
Old Oct 6, 2013 | 08:01 PM
Loop's Avatar
Loop
Red sounds like ATF...Or Dexcron, whatever GM calls it these days.
Could also be coolant...
Old Oct 7, 2013 | 12:17 AM
Baron7700's Avatar
Baron7700
this
Old Oct 7, 2013 | 08:06 AM
wayback's Avatar
wayback
I thought it was just an electric pump, but still hydrolic in nature. Am I wrong?
Old Oct 7, 2013 | 08:50 AM
Road Rage's Avatar
Road Rage
Been a while since I worked for Chevy but I'm sure electric p/s has no fluid.
Old Oct 7, 2013 | 09:40 AM
schilitj's Avatar
schilitj
Nothing on the floor this morning after driving it last night. Maybe just a fluid burp as suggested.
Old Oct 7, 2013 | 09:50 AM
kozmic's Avatar
kozmic
New car, brand new model, oily substance in weird place...
If you cannot definitively determine where it came from, I wouldn't assume anything - I would have it checked.
At the very least, I wouldn't want oil on my brand new car's carpet?
Old Oct 7, 2013 | 12:12 PM
autocross_mitchell's Avatar
autocross_mitchell
man I would for sure want to have someone check that out ASAFP.
Old Oct 7, 2013 | 02:01 PM
vetteLT193's Avatar
vetteLT193
what color is the magnetic shock fluid?
Old Oct 9, 2013 | 08:51 AM
erikszr1's Avatar
erikszr1
carpet? i think he means the floor outside the car. lol
Old Oct 9, 2013 | 09:02 AM
kozmic's Avatar
kozmic
Oops, somehow I read, "front" as "foot" in the title. (kozmic ---> )
Anyhow... doesn't change my opinion that it should absolutely be checked if it cannot be determined where the fluid came from.
Old Oct 15, 2013 | 05:31 PM
TEXHAWK0's Avatar
TEXHAWK0
If it is an automatic, check the lines from the transmission to the radiator.
Old Jun 12, 2014 | 10:39 PM
Stinker Toy's Avatar
Stinker Toy
Z51's have an issue coughing up crankcase oil on the right front. This happened to mine. There's a TSB on it. Can be caused by overfilling or a stuck PCV valve. Check to see if it comes out of the air intake tubes.
For more info, see the threads under major oil leak.
Red oil is confusing--using Royal Purple?
Old Jun 13, 2014 | 06:48 AM
NSC5's Avatar
NSC5
Dexcool is usually an orange color and it would be easy to compare what leaked to what is in the coolant reservoir.
It sounds like ATF, do you have an automatic transmission? If so get it checked at the dealer because there isn't a vent for the auto up front and leaking cooler lines generally don't self repair.
To Fluid under right front
