Z51 Brake Pads
I want to get Ceramic Pads to attempt to eliminate the Dust from these brakes! I will never be tracking the car (I have the supercharged Lotus when I feel the urge
Appreciate any input or information............
The fronts appear similar to the Camaro SS but the rears are way different.
I'm having race pads made for the cars and should be done shortly. I don't know of any ceramics. Might not hurt to see about getting the pads from the base cars to see if that dusts any less.
My question is what do I gain by doing all this? I don't plan on high speed events but will be autocrossing, which a lot less brutal.
So I bedded the brakes as in the manual (take Dramamine first if you are the least motion sickness prone as repeated .8 stops can really do a number on you even when track events do not.) and the judder went away for the most part.
As for the post about finding a lower dusting pad: I consulted Stop Tech and he matched me up by dimensional specs with a Camaro SS low dusting semi-metalic pad. I just got them today so I haven't put them on yet. They should need no bedding (and hopefully the brake squeal will cease). I will, of course, have the rotors turned first (as always when installing new pads) according to the stop tech specs for getting rid of the metal and deposits that caused the judder in the first place. Here's the reply and part # from Stop Tech:
"After locating the new pad shape dimensions and comparing them with existing models, it would only appear that we can supply a front pad alternative to the OEM pads.
The PosiQuiet Semi metallic front pads which would offer good performance compared to stock with much less dust can be ordered with part number 104.14740, however the hardware kit that ships with those pads is for the Camaro SS and would not apply to your calipers."
I just looked for a local supplier listed on the Stop tech web site and they drop shipped me a set for the fronts for about $65. I'' post an update after installation next week hopefully.
Hope this helps
I ran across this post:
http://www.essexpartsblog.com/news/c...y-track-worthy
Scroll to the bottom where he lists C7 Z-51 brake pad shapes.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F $162 R $164 This includes 5%forum discount.
