Katech development C7 baseline chassis dyno
Old Oct 15, 2013 | 08:40 PM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
Default Katech development C7 baseline chassis dyno
Now that the car is broken in we put it on the rollers today. It put down 412rwhp bone stock. After fabricating some dyno peripherals it looks like we're finally going on the engine dyno tomorrow with our spare LT1 test engine. I've been anxiously waiting for that.
http://www.youtube.com/watch?v=OKSOw...ature=youtu.be
__________________
Contact:
(e) zach@katechengines.com
Old Oct 16, 2013 | 09:00 AM
sammyv's Avatar
sammyv
Looking forward to your results!
Old Oct 16, 2013 | 09:27 AM
keagan's Avatar
keagan
Nice Jason, looking fwd to what you and halltech come up with, both numbers and cosmetics.
Old Oct 16, 2013 | 12:32 PM
Katech_Zach
Old Oct 16, 2013 | 01:52 PM
fnbrowning's Avatar
fnbrowning
This is the 2nd dyno I've seen with the stock C7 ~413hp.
I find it interesting this is the exact horsepower my C6 puts down with high lift rockers & Melrose headers, w/o a tune. I also hasten to point out that my 2009 with the Z51 weighs less than the C7 does . . . .
Of course, the C7 engine will soar to new HP with mods, as all the other LSX engines have done.
But in the meantime, I find it comforting that I won't be embarrased by any stock C7 I meet on the road.
Old Oct 16, 2013 | 02:03 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Well the only one you can run up against in STL (for now) is me. Better hurry - won't be stock for long!
Had to give you crap.
Old Oct 16, 2013 | 06:22 PM
PRE-Z06's Avatar
PRE-Z06
I'm not saying the C7 will beat you as it's gonna be dependent on driver skills of both, but you can't just compare peak numbers especially from a different dyno...that's how you lose money in races
Old Oct 16, 2013 | 09:11 PM
JMB's Avatar
JMB
Active Streak: 90 Days
Jason, thanks for being the 1st guy on the planet to post the A/F on a dyno run!!!
Old Oct 16, 2013 | 09:19 PM
JDP Motorsports's Avatar
0JDP Motorsports
Former Vendor
St. Jude Donor '12
I'm looking forward to seeing what you guys come up with!
I've seen 12.0 to 12.2 AFR on the stock C7's we've had on the dyno which is interesting with the DI. They generally like to be a little leaner and I would have expected 12.8 to 13.0 myself.
Kind regards,
Jordan Priestley
888.308.6007
Old Oct 16, 2013 | 09:50 PM
obzidian's Avatar
obzidian
St. Jude Donor '09
Seriously! I was starting to think it was one big secret or something... Like the curb weight.
Interesting how lean it looks from factory. Any timing info at wot?
Old Oct 16, 2013 | 10:06 PM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
That's fantastic and I'm sure you're very proud.
Did your almighty C6 put down those numbers on either of the dynos in question?
S.
Old Oct 16, 2013 | 10:35 PM
3 Z06ZR1's Avatar
3 Z06ZR1
It's the under the curve where the lt1 beats the ls-3. Loses ground then can't pull back!
That's where you need the A&A kit!
(Had to throw a plug in)
Old Oct 16, 2013 | 11:05 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice to see decent stock numbers
Old Oct 17, 2013 | 08:48 AM
fnbrowning's Avatar
fnbrowning
S.
I read your half-baked sarcasm. Weak.
Dyno have always been used on all auto forums for general comparisons.
I made a comment on a comparison between a lightly modded C6 and a stock C7. Obviously the C7 will make even more power with the usual mods. I can deal with it. You need to be less tightly wrapped.
Old Oct 18, 2013 | 02:18 PM
Katech_Zach
fixed the quality of the video
Old Oct 18, 2013 | 06:59 PM
niphilli2's Avatar
niphilli2
Hi Jason,
Do you guys have any prior experience with DI? I am surprised (as others are) at the A/F. If I remember correctly even boosted DI applications have been tuned leaner than that from the factory.
Any comment?
Old Oct 18, 2013 | 09:26 PM
Katech_Zach
Originally Posted by niphilli2
Hi Jason,
Any comment?
That is a factory tune in the graph. We didn't tune the car.
To Katech development C7 baseline chassis dyno
Old Oct 19, 2013 | 09:59 AM
niphilli2's Avatar
niphilli2
Sorry about the confusion, I knew this was a factory tune.
I am wondering why it is so rich? I have little to no experience with DI, but it seems that I remember seeing BMW335 dyno sheets (turbo DI) with cars that were extremely lean in the mid range (all the way up to peak torque) then flattening out around 13:1.
Old Oct 21, 2013 | 07:18 AM
niphilli2's Avatar
niphilli2
Found one, this is a stock BMW 335 (DI Turbo Six):
Note the A/F, very similar..I remembered wrong ...
Old Oct 21, 2013 | 03:58 PM
Katech_Zach
By GM production standards its lean.
