C7 clutch
Single pressure plate and two discs separated by a floater.
We'll let you guys know what they will hold, etc. later this week. We're just waiting on the flywheel from GM.
That has been answered, I'm not sure I'm understanding what you're asking...
Part numbers are different
Correct, the only other hp GM vehicle that had a dual mass was the CTSV's/ZL1. It allows the use of a rigid hub while still keeping the NVH down. This is a terrible setup, plain and simple.
Justin
NVH = Noise Vibration Harshness
Those change all the time, the same part can have different part numbers because they have a different BOX. I would put allot into that until you have both of them sitting side by side. I can tell you by looking at your picture, it looks identical to the CTS-V one I have sitting upstairs. Do a part number search and see if it was a superceeded number.
Justin
As far as my "not even close comment", that was made because the average guy couldn't make this work, it's not even close. 8 bolt vs 6 bolt and a stack height that is just absurd. LOL
We're working on a flywheel for this as I'm typing to convert these to everything 6 bolt, we should have something in a couple of weeks.
We've also already made dampened hub discs for these and had the hardware made when we pull them a part to put the dampened hubs in them.
We'll beat the crap out of them, test the high rpm release, etc. to see if they are indeed better than the predecessor.
Twin disc unit pressure plate, sorry for the confusion.
Justin we've had them side by side, there are some small variations that make them different. Now, we all know GM will update things from time to time so the original CTSV clutch I've got here may be superseded to what the C7 has now...
