Which Supercharger
Please would someone help with this decision, making my head spin!!!
Thanks in advance.
Jay
Thanks in advance.
Jay
Edit: A comment on the conservative tune part: you can blow your motor up with an aggressive tune and a bad tank of gas, happened to a friend of mine and read about it many times. Best to stay conservative.
Thanks in advance.
Jay
My personal choice would be ECS with A&A or Procharger as quick second. That may change once we see more detail on the A&A kits. ECS and A&A have notoriously been the kings of the corvette blower systems for years now. When you base your entire business on a single platform for the most part you are bound to be better than the competitors that offer wide varieties of blower systems.
On another note, prochargers system does look very nice and it is currently available unlike A&A. So really your only choice is ECS or Procharger. My dollar goes to ECS simply because the "base" blower that is included in the kit has more capability and room for power increase without upgrading the head unit than the base blower included with the procharger kit. Both kits are about the same price. Both will work great and are well engineered.
I would personally stay away from any of the positive displacement or screw type blowers (edelbrock, Magnuson, Whipple, Kenne Bell)
The centrifugal blowers will be more efficient and run cooler and also make for a faster car.
If you simply want big block torque off idle and like to smoke tires without really caring how fast the car is, than a screw blower is for you.
A&A isn't out yet but their systems are nice too. I've installed A&A, ECS and procharger on c6. ECS>A&A>PC on the c6, who knows on the c7 yet since not a single person has seen all 3 yet in person. Right now no one has installed more than one kit so it will be hard to say but I know you can't go wrong with the ECS kit.
If you aren't doing the install yourself get what your local shop/etc will support but I strongly suggest the ECS kit.
It does look like PC is moving forward and may have fixed the issues of the previous kits but it is a bit early to see. I wouldn't gamble on it. Too many people swapping PC brackets/etc for A&A/ECS setups to make me want to gamble that they actually did a decent job on the c7 kit.
I think its not good to have a black supercharger as it will absorb more heat from the engine than a polished or satin finish.
The brackets haven't been an issue, it is the tensioners/idlers/etc they use. A&A and ECS have always had MUCH nicer tensioners/pulleys/etc.
Anyone claiming one is perfect/etc is just fan boy nonsense since no one has installed a PC kit besides PC, and no one has installed multiple vendor kits yet. I was going off historical c6/c5 stuff. I'll be installing an ECS kit in a week or so. Wait a month or two and get some more real world feedback. So far the shops/customers with ECS kits are very happy and it is making great numbers. Hopefully we see the same with other brands.
Custom intercooler is funny. As someone that has made a ton of intercoolers in their life I find that term funny to use. Would anything but OEM be custom? Hand fabbed endtanks custom? Cast endtanks custom? What makes an intercooler custom?
I believe ECS said they ship all the OEM parts needed to go back to stock. I guess I'll find out in a week when the kit shows up.
I'm glad posting some solid works drawing really impresses some people.
The swivel tensioners on the ECS/A&A kits are much nicer in design than the rod style in the PC kits from my experience. ECS uses nice steel idler pulleys, others use plastic ones. Not a big deal at first but when you start swapping them out once a year it kind of sucks. I don't know what others are using on c7 kits but ECS always uses top of the line parts.
PS. I'm an engineer so my opinion counts.
What is your opinion on having headers installed along with a supercharger. I have heard different opinions, most are saying it is not necessary and can in fact impact the overall performance.
I'm going to try to pick this apart objectively. I'm not going to be rude, and I'm not going to use any company names and kit types, because it's unnecessary. Please don't take this as an attack - I'm merely trying to counter-point some of these in an objective manner. I'm sure others will appreciate it.
To the OP, you will find arguments in every thread - quite simply, we've all been on the fence looking at each of the kits. The only definitive answers you will see are usually coming from people that don't have the kits, and have never seen them for that matter... Choose your advice carefully, and make sure to call the respected shops here.
They're extremely helpful, and are dealers for all of the brands discussed on the forums.
See what happens when you want to use larger head units on these kits - I'll bet dollars to donuts that you'll wind up in the same place. If this really does it for you, and makes you feel good about your decision, then I suppose that's fine. Others shouldn't continue to hear this nonsense, however. All five major vendors have explicitly stated that it is a non-issue, and one of the leading tuners and vehicle manufacturers laughed off the implication that it was an issue.
Now that I can't argue with - we have several great kits to choose from. It really will come down to individual preference - be that price, installation difficulty, power goals, emissions, etc. Lots to look into here for all of us.
Last edited by Theta; Feb 12, 2014 at 07:19 PM. Reason: Edited wording to make it clearer.
If you want 550-600rwhp or so then just bolt the blower on and enjoy it, but if you want to start turning it up then it is time to add headers.
I would look at doing some cat elim pipes if you don't want headers, or knock the cats out. I've seen too many bad things happen from people melting cats and then losing motors. I personally will never run cats on a s/c car but some people do with success, but I error on keeping the motor alive.
I like the Procharger bracket which fits on with no moving anything.
but not that adjustor or blower But rather have 1500 or t trim or even si.
In that case the ECS bracket, but I like the A&A or Procharger intercooler in that order.
I like parts of all 3 but none of the total kits do I totally like.
So far but have not seen every part of all the kits.
Here's my choice's in order!
Bracket------------ Blowerhead----------- Intercooler
Procharger --------------- ECS or A&A -------- A&A
ECS -------- ---------- Procharger -------------- Procharger
A&A ------------ ---------- --------------- ECS
I like the Procharger crank pulley system have not seen the others system.
So it's tough pick! maybe I'll check the parts to make a perfect kit!
Waiting to see more also!
I'm nearly-positive that the PC and ECS crank pulley setups are using the cam locks (6-bolt). A&A is using an entirely new (machined) part in the place of the factory balancer. Andy just posted pics in the other thread.
This is what we are doing for the crank pulley. It's an SFI approved unit with interchangeable outer pulleys. In my mind this is the best way to do it.
http://forums.corvetteforum.com/atta...1&d=1392252773
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Doesnt take a perfect world. Many of us have been mix and matching ECS and A&A kit parts for years.
This is no different.
Andy's balancer is dope!
That is something I would like to see offered by everyone that is building these kits, its truly worth the extra money. Andy scored big points on that one.
Probably would not be a universal part though as Im sure none of them use the same standoffs or spacing. To use his balancer with anyone elses kit you would have to do some custom work. Not a big deal in the grand scheme of things but would deter the average garage mechanic from doing it.
