Autocrossing
Old Mar 23, 2014 | 07:31 PM
OrioleFan's Avatar
OrioleFan
Default Autocrossing
Can you auto cross a C7 automatic? Or will the transmission overheat?
Old Mar 23, 2014 | 07:36 PM
spwz06's Avatar
spwz06
If you are just playing around, you should be ok. If you are serious, upgrade your cooling
Old Mar 23, 2014 | 07:40 PM
Kracka's Avatar
Kracka
I wouldn't worry about it at all. I would be comfortable autocrossing any car; manufacturers do hellacious durability testing on new cars in far worse conditions than any autocross course will cause.
Old Mar 23, 2014 | 08:08 PM
Magister Ludi's Avatar
Magister Ludi
ABSOLUTELY!
By the end of the day the tranny cooling fan may come on, but I've never seen the transmission temperature gauge get anywhere near the danger zone.
Old Mar 23, 2014 | 11:47 PM
LT1xL82's Avatar
LT1xL82
Originally Posted by Magister Ludi
ABSOLUTELY!
Totally agree. A run at the average autocross is typically what, maybe 2 minutes? The transmission not going to overheat in that amount of time. And there is almost always plenty of cool down time between runs.
Old Mar 24, 2014 | 04:18 PM
ck9887's Avatar
ck9887
I've seen people Autocross econo rentals.... So you should be fine. As others have mentioned, an average Autocross lap isn't much more than a minute. No new production car should overheat under any conditions in that short of time...
Now a road course with 30+ minute sessions... You may run into problems.
Old Mar 24, 2014 | 04:43 PM
Unreal's Avatar
Unreal
Even a 30 minute road course session may not be an issue. The car is built for that. Unless it is 100+ outside, then maybe.
Old Mar 24, 2014 | 04:57 PM
ck9887's Avatar
ck9887
Actually... It has been noted that the Auto tranny may have cooling issues under these conditions and is not intended for track use.
Old Mar 24, 2014 | 05:57 PM
Magister Ludi
News to me.
Old Mar 24, 2014 | 06:18 PM
glass slipper's Avatar
glass slipper
Links to where it has been noted...facts by proclamation are not accepted.
Old Mar 24, 2014 | 09:21 PM
ck9887's Avatar
ck9887
Actually, I may be mistaken. I believe I was thinking about the Convertible which does not have the cooling ducts and GM noted that cooling issues could arise when tracking the convertible.
Although I did search for issues with the Auto Tranny and came across this.
Quoted from this thread
http://forums.corvetteforum.com/c7-g...ng-issues.html
"Tadge commented in a session last week at Sebring that they would be doing a lot of engineering to get the cooling on the new A8 in the Z06 to allow it to survive in a track environment. To use his words he called it "Track certified". If they are having to do that much work on a new design with external pumps and valves I'd say this it's quite likely the A6 is not track certified. if it was I wouldn't expect it would need a cool down after 5 laps."
Old Mar 24, 2014 | 10:21 PM
Magister Ludi
Fair enough. I'm no expert either.
Old Mar 25, 2014 | 10:51 AM
Unreal's Avatar
Unreal
Well add 200hp, and a whole new design and I would expect nothing less than it needing more cooling.
Old Mar 25, 2014 | 10:54 AM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
To Autocrossing
