A/C compressor question
Old Mar 24, 2014 | 01:44 PM
Florida C7's Avatar
Florida C7
Default A/C compressor question
I live in Florida so keep my temperature setting on low. I have the a/c off and auto off but it keeps blowing cold air.
Does this mean the compressor is still on? Should it be this way? Is there a way to turn the compressor off (the info screen says it is off.)
Old Mar 24, 2014 | 03:10 PM
hope2's Avatar
hope2
owners manual is your friend, turn the blower speed **** all the way to the left.
Old Mar 24, 2014 | 03:39 PM
Florida C7's Avatar
Florida C7
Saw that in the owners manual but want to continue to have fresh air through the vents but compressor off.
Old Mar 24, 2014 | 06:23 PM
glass slipper's Avatar
glass slipper
And this is why I hate auto A/Cs...I don't need no stinking computer telling me what I want, I'll control it myself.
Old Mar 25, 2014 | 11:33 AM
vincent_esq's Avatar
vincent_esq
I have the exact same problem and also wonder if this is normal. I don't know why it should be normal? Otherwise why would there be the AC burton then?
Old Mar 25, 2014 | 01:22 PM
Florida C7's Avatar
Florida C7
Thanks Vincent. At least I know it is just not mine. And why would it say a/c is off when it is really on.
The only way to make cold air from warm air is to run it through the system with the compressor on.
Old Mar 25, 2014 | 05:01 PM
vincent_esq
I remember reading about this late last year, but I can't find the thread anymore, but some people were having the same problem. I bet as the weather warms up, we will have more inputs about this issue.
Old Mar 30, 2014 | 05:08 PM
Florida C7's Avatar
Florida C7
Default I think I found fix
Was out today and found if temperature control was on Lo the compressor was on but if I turned it to 61 it was off.
Old Apr 3, 2014 | 03:24 PM
vincent_esq
Default AC always on if temp is on lo. To manually set, it ha to be 61 or higher
Hi Florida C7,
You are totally correct. I can confirm this: If AC temp is set to low, the auto climate will take over and compressor will turn on even when you set AC button to off. (You can still set fan speed though.) IF you set it to 61 degree or higher (one notch above low), then you can manually set the AC to turn on or off. I looked in the manual, and no where does it say this.
Old Apr 3, 2014 | 04:59 PM
Wormwood's Avatar
Wormwood
Hi Florida C7,
I can confirm other car manufacturers are doing the same logic of running the compressor independently from of the indicator bulb or control switch.
If anyone could introduce me to those who head up the GM division that's responsible for approving this to production, so I could put their sign around their neck. It's probably the same crew who came up with the seat memory!!
Old Apr 4, 2014 | 11:01 AM
savage's Avatar
savage
Default i smiled with the 61 fix.
then you had to ahead and bring up the memory seats, i have a two driver car, we no longer even talk about them, the easy exit (THING) ( at start up, at door open, ect is a bad joke! WHAT HAPPENED TO THE DAY WHEN YOU UNLOCKED THE DOOR WITH YOUR FOB, YOU WERE DONE. sorry! that was not ment for you
To A/C compressor question
