MPG test complete
Old Apr 21, 2014 | 09:36 PM
NickHall's Avatar
NickHall
Madison Wisconsin
Default MPG test complete
I just came back from a 1,200 mile mileage test of the C7 Z51.
I put 500 miles on the car to get it mostly past break in before the test.
I ran the car at speed limits in 100 mile tests.
Result, 27.4 average highway mileage.
Result did not vary much in any mode.
Eco mode was not the best millage mode.
Best 100 miles was 30.2 MPG.
Worst was 26.4 against a head wind.
Test was over mostly flat ground from Wisconsin to Kentucky and back.
Old Apr 21, 2014 | 09:46 PM
robertf97's Avatar
robertf97
Thanks for posting. Auto or manual?
Old Apr 21, 2014 | 10:20 PM
NickHall's Avatar
NickHall
Madison Wisconsin
Default 7 speed
Manual trans. most all of trip in 7th gear cruse control on.
Old Apr 21, 2014 | 10:40 PM
slief's Avatar
slief
Your milage will improve greatly with more miles on the car. After about 1700 miles on the odometer, my MPG really started increasing substantially. At 2000 miles I was able to average over 30MPG where as on the same road I was seeing nearly 10% less not 500 miles sooner. I've compared 4 cylinders vs 8 cylinders in other modes and Eco does make a difference of at least 1-2MPG in cruise at 65-75MPH assuming you are able to hold 4 cylinder mode with cruise control on. I'm at about 2500 miles on the car now and MPG is still improving over the same stretch of highway that I travel every day.
I too have a Z51 7 Speed.
Old Apr 22, 2014 | 12:31 PM
PRE-Z06's Avatar
PRE-Z06
Curious what your average speed was or what did you set the cruise to?
Old Apr 23, 2014 | 08:34 PM
NickHall's Avatar
NickHall
Madison Wisconsin
Default MPG increases with miles driven
Thanks, I will watch that over the next 2000 miles. I drove at 4 miles per hour over speed limit, generally at 69 except in Illinois where limit went to 70. There I did 74. Maybe there is a richer mixture on the injectors until x miles are driven, or the engine and trans seat well and reduce friction, or both?
Old Apr 23, 2014 | 10:16 PM
C7pimp's Avatar
C7pimp
I averaged a best of 36.8 mpg in a 25 mile stretch. 2nd best was 35.9.
50 mile stretch is 34 something.
The car is great on gas when you want it to be.
Old Apr 23, 2014 | 11:14 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Being in boost makes my MPG reading a sad panda... Averaging 15mpg combined city/highway.
Old Apr 24, 2014 | 01:10 AM
wuznme's Avatar
wuznme
I did a 750 mile trip, ave 31.9 for the whole trip and the last 350 ave 34.0
1LT 7-spd, cruise set at 7-8 over limit...72 or 78 MPH
First leg of trip was ECO
Best 50 was 38.1
Old Apr 24, 2014 | 12:33 PM
C7pimp's Avatar
C7pimp
Lol, I don't feel bad for you!!
Keep your foot out of it and you'd do just fine.
But, that's not why we install superchargers, is it?
Old Apr 27, 2014 | 01:40 PM
NickHall's Avatar
NickHall
Madison Wisconsin
Default Wow, cool.
Best 50 was 38.1
I had my cruse on the entire time of each 100 mile test, so that should have helped a bit. I will do it again after break in is over and see what I get. I am hoping to see a somewhat steady 30+ in steady flat conditions. I see a lot of people are already there. I will run a new test to KY again next time I go.
Thanks to all,
Nick
Old Apr 27, 2014 | 02:07 PM
Theta's Avatar
Theta
In all seriousness, I did a 50-mile test yesterday in Sport with valves wide open in a mix of 5th-7th and got 26mpg. (And I'm running rich) So that's not bad at all.
Old Apr 28, 2014 | 01:59 AM
Skunkworks's Avatar
Skunkworks
I’d guess you were closed loop just cruising around, so how did you wind up rich?
Old Apr 28, 2014 | 02:02 AM
Theta's Avatar
Theta
Good point......
Well, in that case, I blame my foot for getting into boost now and then.
Old May 2, 2014 | 08:59 PM
jb306y's Avatar
jb306y
How about 37.2 last weekend coming back from the Bash. The cruise was set at 65 mph, with M7 naturally in E Mode.
Old May 2, 2014 | 10:42 PM
BERETTA's Avatar
BERETTA
I CANT drive 65! good result
Best I have done is 26.8 but I very seldom get under 80.
To MPG test complete
