Braking failure at track today
I'm about ready to start track season in Ohio and this is an eye opener.
Glad you all and the car seems OK!!
It sounds like the fluid boiled, especially since "pumping" the brakes brought them back somewhat. Bear in mind, under braking pressure, fluid often doesn't boil...it's when you're off the brakes and the pressure is lower that it boils in the caliper.
Some tracks you can get away with a stock temp fluid, some tracks you can't. I ran stock fluid at Daytona, but wouldn't consider running stock fluid at Sebring, Homestead or RA. This could have happened in a few laps because the fluid, because it's hygroscopic, had a decreased boiling point.
S.
I honestly think there was some kind of electronic issue going on. The brake was rock solid when he pushed on the brake and shifted from 4th to third. The brake felt like when the car is off. There was also no rev match when shifting from 4th to 3rd. He held the clutch in and once we hit the dirt began to pump the brakes and they came back. The where not mush, or faded. It was as if the rev match and brakes thought the car was off.
There is no real on or off with the power brakes, the power assist uses engine vacuum and when accelerating there is no engine vacuum, decelerating there is plenty. These cars have an auxiliary pump (silver cylinder on the LH side by the brake master cyl) to supply vacuum if there isnt enough from the engine, pretty common these days.
Its possible, but with no assist there still is some braking if you really push the pedal hard, but going that fast its easy to think the brakes are out if the power assist is gone.
The way the ABS is set up there is no way the the ABS can completely shut down braking on all four wheels, well thats how its designed anyhow..
we get nowhere fast taking a car to the stealer with a problem we cant replicate and a problem that requires a racetrack. what is the tech going to do to diagnose something like this? GM does not provide stealers what they need to fix issues like this.
once your buddy nails the steps to reproduce the problem, you can try it as well as the stealer. Doing this removes any question about the drivers skills and abilities handling a car of that caliber. further, you will be able to verify if the brakes are fixed when the stealer says its fixed.
I have a history of tracking corvettes and when I was at my peak experience level I tracked 2-4 events per month in my vettes until the seasons ended. I can listen to a coach and WILL do what he says if I think he knows his ****. I've also paid for coaching by racing professionals, one of which became my mentor (and he held a trans am track record at SIR).
After watching the video there were a few factors that push me away from the car having a braking failure to wanting to know more about his driving history. How many times has he driven off the track prior too turn in?
He sped up significantly after passing the camaro. That was quite entertaining and for a moment it looked so fun! However, after passing that camaro he may have felt obligated to maintain that *huge* incremental jump in pace so he doesn't slow down the camaro right after passing it. He is in a new car that he doesn't know and it isn't his. Could these factors put him well out of his comfort zone? Could he have mitigated risk (got cold feet) by driving off instead of completing turn-in? It did look like the vette slowed down quite a bit before following the skid marks off the track. I've never been on that track. Was he going slow enough to complete turn in when he flinched the wheel?
Bottom line is the cars braking system failed. I want to know why. I have been in contact with my dealer since the incident, and have made an appointment to bring the car to my dealer this Monday.
Will you post what the dealer says? With luck, there might be a known issue with the brakes and they know how to handle it. The local stealer here said they didn't have any C7's (a couple months ago) because there were quality issues holding up delivery.
Good luck.
S.
Good luck.
S.
I haven't boiled fluid before (Motul baby!) so I don't know first hand what it is like. To repeat 'pit talk', I heard when brake fluid boils the pedal gets mushy after the fluid has cooled off and to fix it, the brake fluid needs to be bled out.
Good luck.
S.
I guess if you want to play back yard scientist you can pull a sample of your fluid and actually test the boiling point, I bet you will be surprised at how low it is. Just a little moisture (which happens readily with time) greatly reduces the boiling point and stock fluid has a fairly low boiling point even when fresh.
My friend was there with his 2014 AMG C63, I had noticed he pulled in after 3 laps, I took my car around one more time then came into the pits to see why my buddy came in early. Said the C63 overheated and went into limp mode, this is a car with 2500 miles on a 68 degree day WTF!!
I tell him we still have 10 mins in our run group and to try out the C7, so we take the car out with my friend driving. He does the first lat at about 6/10th to get a feel for everything, 2nd lap he starts pushing a bit harder about 8/10s. Everything is good, no fade, no smells, just running perfect.
On turn 8 which is a long sweeper, we are going about 95mph, we reach the braking zone, my friend hits the brake, and NOTHING! We go straight off the track, not turning, in the dirt. Without taking his foot of the brake he starts to pump the brake pedal, and the brakes come back. He gets the car stopped, we took the car directly to the pits to check it out. Fluid is fine, not boiling, nothing seems wrong.
We talked to other Corvette guys at the track, mechanics at the track, nobody can figure out how this happened. The pedal was firm, so sign of fade. Just no braking zero. We had a GOPro in the car, we are going to review it tonight.
The car is fine, just got dirty. I contacted my dealer, and will bring it in for a full check up, but this seems very bizarre to us. Any thoughts or advice?
The boiling point of ANY brake fluid is severely compromised by the absorption of water, and as we know, brake fluid is highly hygroscopic.
Three weeks ago, I ran my track car at Sebring two weeks after running at Daytona with fresh everything. Brakes were solid all day Saturday with the increased cooling that we installed prior to the Daytona event. Sunday, I was 25 minutes into a session and on T7 I noticed them fade slightly as I was hitting my turn-in. Aware of this, I ran through T8-T9, and lifted early into T10, hitting the brakes at the #4 marker instead of the usual #3 (105 mph vs. usual ~117 mph). I had no brakes...just two easy turns and ~1300' later. I pumped them a few times with no luck and turned the car in hard in an attempt to put it sideways, which worked. I slid across the right side rumble strip, through the grass, across the track and off the other side, keeping the car sideways. No damage, just lots of dirt and dust. It can happen quickly, and it usually happens when off the brakes then on them again.
S.
It's been several years since I did any similar events but I have seen or experienced about every type of brake problem at a track event.
I don't think a firm pedal is a sign of boiled brake fluid. More like new brake pads that are outgassing, also called green fade.
Bedding-in new pads usually takes care of the problem.
I'm betting it was not driver error.
