no way the fluid boiled....only 2 laps and he was driving slow....pedal linkage binding???
You can boil stock fluid in many cars in less than one lap. You can fade stock pads/rotors even with upgraded fluid in many cars in less than one lap.
S.
S.
Original poster has yet to tell us what brake fluid he was using...seems to lost interest...
Streetable pads/fluid aren't designed for hard track use. Unless you have a C6 ZR1 with the carbon ceramic brakes, you need to upgrade the pads and fluid for track use... if you're an advanced driver. For the novice the stock stuff will be fine to get your feet wet. Been racing/instructing with NASA for a decade.
S.
NEVER SAID THAT ....I SAID no way you can boil C7 brake fluid in 1 and half laps......
beside ive boiled my fair share of brake fluid....i even boiled it driving on the street and its takes more than just one or two seconds for the fuild to cool off,,,,,more like afew corners to half a lap to get the pedal back......this guy claims to get the pedal back after only afew seconds
When you boil fluid in the calipers, it transforms to a gaseous state, which means that it compresses more easily than when a fluid. Typically, pumping the brakes several times will get some degree of pedal return (assuming you have time to do that). It doesn't have to be "a few corners" (which defies logic since you're on the brakes in the braking zones approaching those corners) or a "half a lap".
S.
And I'm telling you that you can boil fluid in the calipers and fade brakes at very, very many tracks in less than a full lap.
S.
ok then easy 10 grand cash for you.....ill supply the stock c7 at carlisle 2014....you drive the slalom course.....ill give you 3laps....ill record your gas pedal positions with my scan tool .....temperature stickers on all 4 calipers.....deal??????
S.
speaking of defying logic isnt it logical that after experiencing a soft or floored brake pedal a logical person would then slow right down, cruise the next few corners to half a lap frequently checking for return of the brake pedal and not try to continue at the same pace that boiled the fluid in the first place as you insinuate?????
Are you really considering the "slalom course" at Carlisle a race track?
Seriously?
S.
Typically, lots of drivers won't have that chance.
But yes, if the pedal goes soft or "floored", that would be an instant clue to get out of it and pit in. However, since fluid often boils when there is no pressure in the system (between corners...and because pressure raises the boiling point of liquids), it can boil in the calipers between corners.
S.
Seriously?
S.
well thats why i doubled it and gave you 3 laps.....fine then make it worth my while to fly down there all the way from polarbear country ....20 grand and a lap and a half of willow springs the exact track this happened
S.
op made it clear the pedal was floored and zero brakes, not a soft pedal with some .......thats means it was extreme fluid overheating.....but yet the pedal came right back in seconds .....therefore no way the fluid was boiled in the first place let alone in 1.5 laps in a c7 at that modest pace
Sure...you don't even have to fly to California.
I'll take that bet at Sebring. I'll even keep my own C7 in Florida for a few more months. There is a single day event with Chin in July. We'll find an escrow to hold $5k each on a $20k bet. You can datalog the car however you'd like and I'll have XP Motorsports monitor it as well. The car will be 100% stock with factory fluid and pads in it.
What now?
S.
The pedal came back after the driver pumped it, which is common with boiling brake fluid.
S.
