Please explain transmission ratios
( my car is from the 2nd release to dealers where GM has already updated the ECM's to a new operating system different and better than the 1st release)
This is one article explaining the new A6
http://www.vetteweb.com/tech/1312_20...rack_mode.html
The drivetrain loss on ANY STOCK Trimec is known to be from 10-12 %
Now making the C7 A6's equal to a manual trans in RWHP compared to the C7 manuals and better than a C6 manual-----
A8 looks damned good and this is the 'trend', my friend in vehicles in general from light trucks to luxury cars.
Sports cars may be a different matter. CVT so far is impossible to design for a Vette and there is always the question of slippage.
A torque converter will do a better job both in comfort and endurance for general purpose vehicles. Drive a Lexus and then drive a Panamera. GM engineers have taken ZF and Asianne gearboxes and vastly improved the design. Keep your eye on it's development. It won't replace the sequential on the race car however.
Foreign high performance cars use DCTs but in the real world, there are penalties such as I have mentioned plus excessive mass and redundance. Ultimate performance comes from sequential gearboxes and so far, the LFA is the only car that chose it.
Yamaha designed the engine and gearbox with some Honda patents, (Seamless ratchets) It is not necessary for a CVT, but a LFA type sequential with a TC or without, could address all high performance applications.
Oh, and I also mentioned that the Tremec DCT with hold 664 lb-ft of torque(the Z06 LT4 produces around 635 lb-ft) and is designed for the C7 application. It fits in the C7.
Stand at the bottom of a staircase. Proceed to climb the stairs 3 steps at one time. Run down the staircase taking one step at a time. In both cases, you are in the wrong gear. How do you know if you are in the right gear on your bicycle? Count your crank revolutions and compare it to your rear wheel revolutions in each instance. Measure the daimeter of the rear wheel and the sprocket diameters. Simple arithmetic will display the ratios in math terms.
Every transmission has a different design. Autos have epi-cyclic gears and manual transmissions have constant mesh gears.
In the same way, Wheel diameters, rear axle ratios, gear ratios are matched to engine performance of your car. Max acceleration will occur at shift points which coincide with the max power rpm of the engine and not the max torque rpms. That's another story. The new 8 speed auto is designed to keep the rpm as low as possible at low acceleration to save gas. Ideally, a transmissions should keep engine rpms constant, either at max power, max torque or idle RPMs. See above graph.
To fiqure your gearing ratio's like a Motorcycle!
Simple fact of the matter is that C6 and C5 owners are just pissed that someone with a non-Z51 C7 and a 2.56 rear ratio now is quicker and faster than their bolt on modded cars-
I spent $15k on my '98 A4 to get 475 crank HP--and now stock the C7 has 460----I was pissed too----But you either catch up to technology or fall behind---Just as in professional racing--
It's not magic --It's electronics
Get used to it----
GM has now with new tech. and new electronics-- given the ability for a 1st time Corvette owner with "0" experience and an automatic to run in the low 12's and a mid 4 second 0-60 time--and its making people mad---
On my C7 with 35 psi in the tires---on the street--set on touring mode and in drive--with FULL traction control on consistently ran a 4.5 0-60 time-------and yes on a sticky drag strip with TC turned off and some experience they easily will do the claimed 3.9 or better---
PS: after tuning my car---on the street--in Track mode I ran 4.1's 0-60 times---
Get used to it----
Thanks, Chris
maybe when the new Z06 8 speed A8 comes out and it will be quicker than the 7 speed manual you'll finally get the point--
read the posted article.... what a classic.
I said the horsepower is UNDER-rated, meaning that the rear-wheel dyno numbers are higher than they should be for the rating, not to mention the variations in dynos and the differences between the factory SAE rating and the fact that many dynos are run STD, facts which preclude comparisons between chassis dyno numbers and factory power ratings. This point is moot unless you pull the engine and dyno it on an engine dyno before you install it and run it on an identically-calibrated chassis dyno under the exact same conditions..
You need to approach this with less passion and more objective logical analysis. The upcoming 8-speed Z06 should run consistent tens in the quarter-mile on stock tires with any driver who can stay on top of their launch, and that's awesome. I have no doubt that it will be the quickest combo ever offered in a factory Corvette. That still doesn't mean that the electronics make it sap less power; that's ludicrous and shows a fundamental ignorance of how physics work to reduce output. Electronics can't reduce parasitic loss on a drivetrain.
I don't know the weight of the flexplate an torque convertor used on the current A6 or the new A8, but I would guess that the combined weight would be at least 40-50 pounds(SWAG). 219+ 45=264 pounds(SWAG).
The TR6070 weighs 144 pounds + 68 pounds = 212 pounds. Not that much lighter than the Tremec DCT and quite a bit lighter than the A8.
I don't think you would need a dual mass flywheel with the DCT, but not sure, because of the AFM. Possible that on a limited production Z06 with a DCT, the AFM would not be standard thus would use the lighter 25# flywheel, vs the TR60670's dual mass flywheel/dual disc clutch.
I was addressing the weight comparison between the new GM A8 and the Tremec DCT. The DCT with it's flywheel weighs less than the A8 with it's flex plate and torque convertor.
With the DCT, I doubt that you will have the heat build up problems associated with an automatic transmission such as the A6/A8 hydramatic when tracking the car.
For your typical driver, that never tracks their car, the A8 should be an excellent street transmission with occasional WOT's and driving 8/10's on a twisty road. For the person that pushes his Z06, I feel the DCT will be a superior transmission to the A8. My opinion, of course.
That said, my left knee still works for the time being, so I'll be sticking to three pedals
