Old 02-23-2015, 05:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake How-Tos
Print Wikipost
How-To: Replace Parking Brake Shoe, Electronic Emergency Brake Module + Schematics
Old 06-15-2014, 12:51 AM
Theta
Theta's Avatar
St. Jude Donor '14-'15
Default How-To: Replace Parking Brake Shoe, Electronic Emergency Brake Module + Schematics
The following How-To covers the explanation and repair of the Parking/Emergency Brake Hardware and Control Unit and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
jonesaut (09-04-2017)
Old 06-15-2014, 12:52 AM
Theta
Theta's Avatar
Attachment 48371951
Attachment 48371952
Attachment 48371953
Attachment 48371954
Attachment 48371955
Old 06-15-2014, 12:53 AM
Theta
Theta's Avatar
Attachment 48371948
Attachment 48371949
Attachment 48371950
Theta
Theta's Avatar
Attachment 48371946
Attachment 48371947
Theta
Theta's Avatar
Attachment 48371944
Attachment 48371945
Old 06-15-2014, 12:54 AM
Theta
Theta's Avatar
Attachment 48371943
Old 04-28-2015, 02:48 PM
MIGHTYM0USE
MIGHTYM0USE's Avatar
thank you for this. i have blown 2 fuses in a row (second one popped key off engine off just by attempting to install it)
i guess something wrong with the module since not much else to the system.
Old 04-28-2015, 03:42 PM
Theta
Theta's Avatar
Yikes! As you probably know from looking at this, the switch is your garden-variety momentary with lighting and diode protection. The CAN/LIN (Edit: GMLAN) bus communication between the cluster and the module are low-level logic, so nothing that would pop 30A fuses.
Sounds like the module went bad, or you have a short to ground on power wire 1492 or 742.
Old 04-28-2015, 03:56 PM
MIGHTYM0USE
thanks!
if im reading correctly the red/light green power wire goes from the fuse all the way back to the module
and the yellow 12v arm is same from switch all the way to module as well.
the switch did feel a little sticky but it could just be in my head
first i will do is verify ground at the fuse block pin.
i don't suppose you know where connectors x311 and x313 are on the car?
i was surprised to not find a relay in the wiring?
Old 04-28-2015, 05:39 PM
MIGHTYM0USE
i have ground at beginning of 742 at the fusebox terminal and i have ground at the plug at the module. so perhaps the module is ok but why is my red/lt green grounded and where..
Old 04-28-2015, 07:09 PM
Theta
Theta's Avatar
You can check the K83 (Park Brake Control Module) pins to see if the module has internally grounded itself due to a fault.
Pin A - RD/L-GN - Circuit 742 - Battery Positive Voltage
Pin H - BK - Circuit 2050 - Ground
While the cable is disconnected, you can also check at the wiring connector. You'll know which one is at fault after doing this (the wiring or the module).
Old 04-28-2015, 10:00 PM
MIGHTYM0USE
well after unluckily starting from the rear i worked my way to the front and found good old red/light green shorted to the header.
be advised this bundle was not tucked away well and i missed it during header install a month or so ago
Old 04-28-2015, 10:03 PM
Theta
Theta's Avatar
The good part about testing from the module is knowing which one to start checking. Although, I see your point - you went from the back to the front.
I'm glad you found the issue, at least! Far better than having to replace a module.
Old 04-29-2015, 08:53 AM
MIGHTYM0USE
thanks again!
Old 07-19-2016, 12:17 PM
Detroit Steel
CorvetteForum Editor
Detroit Steel's Avatar
Default How-To Tuesday
Great topic for How-To Tuesday!
https://www.corvetteforum.com/how-to...-module-368093
Old 07-18-2018, 05:51 PM
hairymeister
hairymeister's Avatar
Thanks. Now to pull this up in my garage.
To How-To: Replace Parking Brake Shoe, Electronic Emergency Brake Module + Schematics
Quick Reply: How-To: Replace Parking Brake Shoe, Electronic Emergency Brake Module + Schematics
