Z51 E-diff failure first time at drag strip
Old Nov 6, 2014 | 10:13 AM
Ben@WeaponX's Avatar
Ben@WeaponX
St. Jude Donor '14
Default Z51 E-diff failure first time at drag strip
I have thought so far these were pretty bullet proof unless some of the failures hadn't been discussed openly? I know some axles broke but this is the first e-diff to my knowledge? I know in other cars the diffs can bee problematic, but GM's technology on the 4500lb CTS Vs for diffs and axles hardly ever break, so I'm hoping this is just bad luck.
Car:
2014 Z51 7M with Procharger
Craig was having some traction issues with his Michelins so he upgraded to the Toyo R888s on his new wheels and took it to the drag strip to see how his car would do.
Dumped the clutch at 3500 and carnage for the new e-diff and hooking that hard!
Old Nov 6, 2014 | 10:14 AM
WKMCD's Avatar
WKMCD
DAMN!
Old Nov 6, 2014 | 10:19 AM
Fore58's Avatar
Fore58
Toyo 888's must be real sticky.
Old Nov 6, 2014 | 10:31 AM
LT1xL82's Avatar
LT1xL82
Some J B Weld should fix it right up.
That is one sad looking pile of parts. I'd be interested to know if the warranty covers this with there being a supercharger installed.
Old Nov 6, 2014 | 11:15 AM
24/Eray's Avatar
24/Eray
oooph.
Old Nov 6, 2014 | 12:29 PM
Jim Barker's Avatar
Jim Barker
I did this every 6k to a 66 GTO until they added two more pinion gears to the updated HD unit. I was thinking spider gears were a thing of the past with the E-diff using clutch pack to lock and unlock axles and housing, live and learn I guess! Great to see but not at somebody's expense. Thanks for posting
Old Nov 6, 2014 | 04:34 PM
brent eb02's Avatar
brent eb02
Well it HOOKED !!
you know what they say ....if your not breaking stuff...you aint going fast enough !
seriously OUCH !
Old Nov 6, 2014 | 04:48 PM
Andy Sziraki's Avatar
Andy Sziraki
Yowwwww!!!! Damn benny!
Old Nov 6, 2014 | 05:10 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Not good!
Old Nov 6, 2014 | 07:54 PM
W88fixer's Avatar
W88fixer
EEEEEUUUUUWWWWWW!!! What a pain in the wallet. Don
Old Nov 6, 2014 | 08:01 PM
robertf97's Avatar
robertf97
I just decided I dont want drag radials for a while. Best of luck getting it fixed.
Old Nov 6, 2014 | 08:25 PM
LS1LT1's Avatar
LS1LT1
That could be part of the problem.
Those R888s are sticky but they also have very stiff sidewalls that offer no 'give', the axles and rear diff gets ALL of the hit, especially with a manual trans/clutch.
Not saying that on a drag radial with a softer/tall sidewall that it wouldn't have still broken, but I've seen road race/autocross tires destroy rears in the past as well.
Drag radials (or even D.O.T. street slicks - ET Streets/Quick Time Pros) only along with proper pressures and burnouts for a 'stock IRS' car making this kind of power, in my opinion.
Old Nov 6, 2014 | 09:13 PM
BLKTA's Avatar
BLKTA
^^^ That's what I thought. Years ago, I tried to drag race on road race tires thinking the soft compound would help; they didn't and in fact I had some wheel hop which didn't happen on DR's.
Old Nov 7, 2014 | 01:11 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Even a C5 or a C6 with a manual trans was subject to breaking output shafts---This is nothing new for a C7----If you wanna go fast you're gonna break parts---That's why all serious bracket racers go to ford 9" rear ends and heavy duty axles----- A Corvette is NOT a purpose built drag car----Drive it as such you're gonnna break something !!especially if you want to leave hard at 4000 RPM's--
That's why I bought an automatic---The violence at the launch is not as severe ---and these New A6's have the same drivetrain loss as a previous manual trans Like only 10-12 %---------Want to make your manual trans bullit proof ?? And with a SC ?? You must shore up your rear end with heavy duty output shafts and a built rear end and clutch------JMO
Old Nov 7, 2014 | 02:19 AM
LS1LT1's Avatar
LS1LT1
I had actually meant to mention/ask in my post above if there was any wheel hop on this C7 right before (even if it was on a pass or two before) it broke, bad hop will do it every time.
Old Nov 7, 2014 | 07:13 AM
BLKTA's Avatar
BLKTA
I agree on wheel hop. I watched my friend snap an axle with wheel hop during a burnout. Granted it was a live axle car (00 TA), but it's bad stuff.
Old Nov 11, 2014 | 04:15 AM
tblu92's Avatar
tblu92
My 2014 shows no wheel hop at all even with the TC off and the Stabilitrack OFF- It will spin the tires badly but not HOP---My quickest runs were made with both the TC and STABILL, TRACK OFF and by trial and error figuring how to do the perfect feathered throttle launch--
To Z51 E-diff failure first time at drag strip
Old Nov 11, 2014 | 03:08 PM
Randy WS6's Avatar
Randy WS6
My 14-3LT-Z51 M7 with magnetic ride , has some wheel hop at the top of second gear for some reason. First gear, not so much if any. This is on stock tires and in sport or track mode.
What does the C7 use for the torque bushing or mount. Maybe need something in the Prothane to stiffen it up. This is my first vet, so im not too familiar with there suspension setup in the rear. Is there a particular air pressure that the tires need for drag racing ?
Old Nov 11, 2014 | 09:34 PM
lt1z's Avatar
lt1z
yep wheel hop is a killer.
Old Nov 12, 2014 | 12:11 AM
LS1LT1's Avatar
LS1LT1
With runflat tires it's hard to determine, tire pressure with runflats is far less important because the sidewalls are so inherently stiff to begin with. There is so very little 'give' or 'flex' in them even at 0psi.
Personally, I would lower them to maybe 26psi at the drag strip but again it really makes very little difference.
