Throttle body
Old Nov 20, 2014 | 02:46 AM
Seannyc's Avatar
Seannyc
Originally Posted by tblu92
What ??? You can't find a better mod right now for C7 for $150 other than a ported T-Body----Waste of money ?? No way !!! a waste of money is spending $1200 on a cat back exhaust or $1000 for a set of long-tubes---
The stock C7 T-body as other GM TB's has a huge lip on the bottom of the port--about a 1/4" or more---removing that lip makes the air flow cleaner and ultimately lets more air in---As a tuner I could see the added air thru out the RPM band with my data logger that proves it works--and as mentioned I had to de-tune my car to make it drivable as it became too aggressive---- Also---after the install the car immediately idled like at 1500 for 3-4 minutes until the ECM learned out the idle airflow---
It's $350 without installing and only adds 10hp
Old Nov 20, 2014 | 07:45 AM
Tom Kane's Avatar
Tom Kane
Originally Posted by mdime
Hello, has anyone installed the WeaponX LT1 throttle body- Ported in their C7? If so, was it a good upgrade?
Thanks.
I installed it on my C7 auto car AFTER installing new ignition wires, aFe intake and the Diablo tune. Another words, it was the LAST item I did. No question the car ran smoother. Since new, my car had a slight ruffness for a min or two until it warmed up. That went away instantly. Car also felt more responsive. So would I install it again, yes, happy with it.
Old Nov 20, 2014 | 08:40 AM
Kracka's Avatar
Kracka
The installation is very easy, anyone with a set of basic ratchet & socket set can do it. The trickiest part is disconnecting the wire harness plug...otherwise it's as simple as disconnecting the intake tube then 4 bolts which secure the TB to the intake manifold.
Old Nov 21, 2014 | 01:50 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Most places they are only $150 and a core charge of $150---If you send them your core you get $150 back------I got mine from Kieth at KD Innovations
Old Nov 21, 2014 | 03:41 PM
Randy WS6's Avatar
Randy WS6
Is there any match porting need to be done from the outlet side of the TB to the intake inlet ?
Old Nov 21, 2014 | 11:11 PM
tblu92's Avatar
tblu92
Just recently I have seen some who are porting the C7 intake manifold--Just as in the C5 and C6 yes there is some room for improvement---However not much on a stock cubed or stock cammed engine----same was for the C5 and C6----Maybe 5-8 RWHP -- so one of the last mods I would ever do as there is not much there--cam --hds- SC-- Yes you can increase the airflow--but on a stockish engine the stock C7 manifold is very good-- unless you have $500 just burning a hole in your pocket----
Old Nov 22, 2014 | 06:37 PM
Ben@WeaponX's Avatar
Ben@WeaponX
St. Jude Donor '14
I have ported lt1 manifold and it is actually very restrictive. Many pickup 15-20hp on the 376 motor. I picked up 30HP on my 427 when we swapped it. I'm in the process of an aftermarket manifold right now to see what else is left because I'm still seeing air restricted in the log at WOT.
I have something amazing in the works that I'm not ready to unveil just yet, but it will be a game changer!
Old Nov 22, 2014 | 10:40 PM
tblu92's Avatar
tblu92
Awesome---I would sure like you to notify me when you release your new product---and will be interested in a manifold port as well--I've read where the air intake system generally is restrictive on the LT1---I sure could easily tell the difference when I installed an AFE CAI-----
After major modding all my C5's and C6's I have decided not to takes the heads off my new C7 so I would be interested in any bolt on new parts
These engines have a huge potential far beyond any previous Corvette
with stock hds cam---- Thanks Tom
Old Nov 23, 2014 | 06:18 PM
on3wego's Avatar
on3wego
I need one of these what mm is the ported one? Are there any 90mm that fit the car?
Old Nov 23, 2014 | 06:21 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
No 90/92mm TBs that I know of. Of course Ben might know of something custom, but once these OEs are shaved down, they flow quite well.
For what you and I have been talking about, a ported intake manifold is a great secondary to this mod (especially with the direction you're leaning towards).
Old Nov 23, 2014 | 06:30 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Sean,
Are there any of these widely available yet? I know MSD is working on a new one.
Old Nov 23, 2014 | 06:33 PM
Theta's Avatar
Theta
I called FAST a while back and they weren't (saying anyway) working on one yet.
Right now porting is a good (and cheap) option. I was hoping for a drop-in 90/92mm TB/manifold combo, but that would screw with the blower silicone, etc.
I showed a decent amount of pickup with the TB + manifold after throwing the SC on there. Not sure how it would wake up a stock NA car, but the more air you move, the less restriction you want.
I don't know if Ben is going to start porting these for customers, but that's one option. Lost of weird restriction points in the stock one.
Old Nov 23, 2014 | 06:41 PM
  #33
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I think at this point as far as intake and exhaust go, a ported Intake manifold is the only thing that I dont have done yet so I want one. After that its on to the fuel system. "Preparation mods"
Old Nov 23, 2014 | 06:47 PM
  #34
on3wego's Avatar
on3wego
I was hoping to get a 90mm. Bc I wouldn't have to change it later on. I could get it and put it on now.
If Ben knows a secret or somthing maybe he can chime in.. also sean. I sent u a pm I think. I think I replied to my thread and sent u a return pm.
Old Nov 23, 2014 | 07:21 PM
  #35
Ben@WeaponX
St. Jude Donor '14
I'm in the process of making a carbon injection molded high flow manifold with aluminum runners and a billet 102mm TB I'll have some CAD renderings up soon. While the OEM ported TB and manifold are good for increased gains, they are still very restrictive. My LT1 ported TB was a max port, so much the bottom is actually aluminum now and I picked up 30hp over a stock one and there are still restrictions.
Old Nov 23, 2014 | 08:02 PM
  #36
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Perhaps to you. For those of us making real power, it's a good jump at a cheap price. Same with the intake manifold.
For people with minor mods (or even stock), it brings an obvious change in throttle response, which many very much enjoy - power adder or not.
just how much more throttle response can you get if you have a Diablo tune and have the driving mode set on Track?
Old Nov 23, 2014 | 11:09 PM
  #37
Theta's Avatar
Theta
You're comparing apples to oranges - that's modifying the TPS readings to give you a perceived decrease in throttle lag. It's been used for years and called different things (SprintBooster, etc). In a tune, it's a nice (free) bump in perceived performance.
The tune isn't somehow changing the way the air is entering. A physical modification will stack on top of the software 'trick'.
To Throttle body
Old Nov 23, 2014 | 11:10 PM
  #38
Theta's Avatar
Theta
Also... DAMN, Ben!
Old Nov 24, 2014 | 09:54 PM
  #39
T/A KID's Avatar
T/A KID
Ben, thanks for posting. I have done a lot of work on manifolds in the past, and I have a few questions if you don't mind answering.
Is the intake CSA smaller than the head CSA? IF so gains can be made there. How far up the runners is assessable?
I'm sure the factory intake as quite a bit of taper in the runners, but most of these intake are pretty rough inside due to casting so smoothing these areas help.
I've seen you added some epoxy in areas to increase volume area that can be ported, I bet this intake suffers from a lack of plenum volume too even at 376ci, much less at 427ci.
Old Nov 27, 2014 | 10:12 PM
  #40
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ben
Your work is amazing! Outstanding ingenuity.
Bill Curlee
