Throttle body
Old Nov 10, 2014 | 07:20 PM
mdime's Avatar
mdime
Cruising
Default Throttle body
Hello, has anyone installed the WeaponX LT1 throttle body- Ported in their C7? If so, was it a good upgrade?
Thanks.
Old Nov 10, 2014 | 07:49 PM
Kracka's Avatar
Kracka
I have it and like it. Better throttle response and smoother transition into V4-mode. I have stock vs. ported pics somewhere on this board, they hogged out a lot of material!
Old Nov 10, 2014 | 08:47 PM
managerman's Avatar
managerman
Did you also add a CAI? and/or custom tune?
-M
Old Nov 11, 2014 | 09:40 AM
Kracka's Avatar
Kracka
-M
-AFE intake
-Weapon-X ported TB
-Diablo InTune w/AFE93 tune
Old Nov 11, 2014 | 02:26 PM
Seannyc's Avatar
Seannyc
-AFE intake
-Weapon-X ported TB
Did u Dyno it or run it through the 1/4
Old Nov 11, 2014 | 03:47 PM
managerman's Avatar
managerman
Good Question: What real world results have you seen? I am interested in doing exactly what you have done...and the 64,000 dollar questions are: Does it make a difference and how?
Thanks,
-M
Old Nov 11, 2014 | 03:51 PM
Kracka's Avatar
Kracka
It feels better and sounds better...but no, I do not have real hard data. My plan was to get it on the dyno...but life got in the way. I did a stock baseline at 386whp on a Mustang Dyno and plan to do a before/after dyno in the near future once my ported/coated exhaust manifolds are ready for testing.
Old Nov 11, 2014 | 05:58 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I have side by side pics of stock vs WeaponX TB in my build thread. I dyno'd it with all my other mods done and got 430HP and 436TQ without touching timing..
Old Nov 11, 2014 | 06:13 PM
Ben@WeaponX's Avatar
Ben@WeaponX
St. Jude Donor '14
I have some of these in stock right now that I can do $350 shipped with a $100 core return.
Old Nov 15, 2014 | 12:12 AM
Houston C7's Avatar
Houston C7
Default Ordering WeaponX at Discounted Price Question
Ben, how does one order from your site and get the pricing you quoted?
Old Nov 15, 2014 | 03:48 AM
Mecholova's Avatar
Mecholova
Was the car set correctly when you dynoed? 386 seems low for stock.
We hit around 420 stock on a Mustang
Old Nov 15, 2014 | 08:11 AM
Ben@WeaponX
St. Jude Donor '14
I changed it for you.
Old Nov 15, 2014 | 10:35 AM
Kracka's Avatar
Kracka
Every dyno reads differently. 420 would be very high for a Mustang, not many are even seeing that on DynoJets.
Old Nov 16, 2014 | 06:21 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
With the completely new tuning process of the E92 ECM--and after tuning my car myself with EFILIVE-----I actually had to DE-TUNE the TQ response tables from 0-20 MPH-The response was so much more aggressive in my post tuned car that it would lurch forward at every stoplight--Some customers like it that way but for most it is no fun to drive as you have to constantly lift every time you leave a stop light- On an un tuned car it may not be that aggressive---I am 100% happy with my T-body--
Old Nov 19, 2014 | 01:01 PM
ect's Avatar
ect
waste of money
Old Nov 19, 2014 | 04:08 PM
Ben@WeaponX
St. Jude Donor '14
Got your order going out tomorrow Melvin
I have 4 left in stock for the time being guys.
https://weaponx-c7.myshopify.com/pro...le-body-ported
Old Nov 19, 2014 | 10:22 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Originally Posted by ect
waste of money
Perhaps to you. For those of us making real power, it's a good jump at a cheap price. Same with the intake manifold.
For people with minor mods (or even stock), it brings an obvious change in throttle response, which many very much enjoy - power adder or not.
To Throttle body
Old Nov 19, 2014 | 10:37 PM
C2367's Avatar
C2367
The stock looks really nice to me.
Old Nov 19, 2014 | 10:39 PM
Theta's Avatar
Theta
It's really just that lip / step that causes turbulence. Any porter is just removing that and smoothing everything down to create a path of least resistance.
I actually don't have Ben's on mine (I have Formato's), but they're identical in that the main 'culprit' is milled down.
I believe the original design was made with AFM in mind, and I know I've read that somewhere - damned if I can remember anything anymore, though!
Old Nov 19, 2014 | 11:39 PM
tblu92's Avatar
tblu92
waste of money
What ??? You can't find a better mod right now for C7 for $150 other than a ported T-Body----Waste of money ?? No way !!! a waste of money is spending $1200 on a cat back exhaust or $1000 for a set of long-tubes---
The stock C7 T-body as other GM TB's has a huge lip on the bottom of the port--about a 1/4" or more---removing that lip makes the air flow cleaner and ultimately lets more air in---As a tuner I could see the added air thru out the RPM band with my data logger that proves it works--and as mentioned I had to de-tune my car to make it drivable as it became too aggressive---- Also---after the install the car immediately idled like at 1500 for 3-4 minutes until the ECM learned out the idle airflow---
