Lowering bolt install
Old Jan 15, 2015 | 02:44 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
Default Lowering bolt install
i got the kit from Zip corvette and no instructions.
they said to remove the a arm from cradle HOWEVER the gas tank is in the way of the forward bolts.
so whats the deal?
tips/tricks? i found it not possible to remove the leaf with the arms installed. i guess remove the spindle?
thanks in advance.
Old Jan 21, 2015 | 09:40 AM
MIGHTYM0USE
nobody installed these themselves yet? really?
Old Jan 21, 2015 | 09:43 AM
John Micheal Henry's Avatar
John Micheal Henry
Just lower on the stock bolts. Simple..
Old Jan 21, 2015 | 10:05 AM
MIGHTYM0USE
totally wrong answer man, sorry.
Old Jan 21, 2015 | 10:07 AM
MemeG's Avatar
MemeG
7th Gear
My brother did mine a couple days ago. I will ask him and try and get back to you as soon as possible.
Old Jan 21, 2015 | 12:49 PM
MemeG's Avatar
MemeG
7th Gear
so whats the deal?
thanks in advance.
Im not to sure about this but heres the tips and tricks from my bro. End product turned out pretty good.
Fwd:I put the jack stands on the leaf spring bar to take the tension off the stock bolt, all I unbolted was the shock and the sway bar, turned the bolt so the rubber stopper went down then took a sawzall and cut the stock bolt in half below the leaf spring then removed the remaining part of the bolt out of leaf spring. You can then take a pry bar push down on the a arm enough to where you can squeeze the aftermarket lowering bolts might need a hand with the pushing down on the a arm part. I must warn you I did go through about 6 sawzall blades. LOL
Old Jan 21, 2015 | 01:41 PM
Mr Guns's Avatar
Mr Guns
I wish someone had an instructional on how to install them. I've had some lowering bolts for a while but not sure how to install them.
Your car looks great, but I'd be worried about destroying the original bolts. I could be wrong, but I don't think the stock bolts are an orderable part from GM. If you ever want or need to go back to stock, you may have some trouble.
Old Jan 21, 2015 | 02:01 PM
MIGHTYM0USE
obviously vendors here are doing it, just need to get a response.
i would like to avoid sawzall approach! i believe they are removing the lower arm from the spindle. thats my next attempt anyways.
Old Jan 21, 2015 | 02:32 PM
Higgs Boson's Avatar
Higgs Boson
i just cut the lower third off the rear bolts with a sawzall and have had no issues.
Old Jan 21, 2015 | 02:43 PM
MemeG's Avatar
MemeG
7th Gear
From an aesthetic point of view I dont think I'd ever go back to stock height. Hopefully I dont have any unforeseen issues that would require me to take it back to stock height.
Old Jan 22, 2015 | 04:49 PM
Greg00Coupe's Avatar
Greg00Coupe
Should be OK unless you track the car.
Old Jan 23, 2015 | 02:16 PM
MIGHTYM0USE
you should be able to approach stock height with lowering bolts too. you dont have to only use them all the way lowered.
Old Dec 17, 2017 | 12:56 AM
Bmwmike's Avatar
Bmwmike
Any updates on this?
Old Dec 18, 2017 | 01:37 PM
mittens's Avatar
mittens
it takes alot to remove them and replace them..
I cut the first rib off mine. in place
Old Dec 19, 2017 | 09:25 AM
rrsperry's Avatar
rrsperry
Man you'd be hating life around here... I think the regulations say that speed bumps must be about 11" tall...lol (ok, they are really, but they are tall enough that lowered on stock bolts is a challenge...) Either that or the paving companies just wanted to use all the asphalt mix that day...
Old Apr 20, 2026 | 10:23 AM
ir0nman11's Avatar
ir0nman11
Did you ever end up figuring this out?
Old Apr 20, 2026 | 04:41 PM
9sec's Avatar
9sec
lowering bolts either go up our down. turn then up the car lowers turn the down the car raises not much else to do
To Lowering bolt install
