C7 sway bars choices?
I'm curious as to how they determine the adjustability on these.
Stock C7 Z51 with MRC
Front 28mm
Rear 31mm
Pfaftd
Front 35mm
Rear 32mm
It looks like they beefed up the front ALOT more than the rears. Knowing that almost all cars come from the factory with understeer, woudn't increasing the front bars that dramatic compared to the rear cause it to understeer even more? I'm hoping to have a very balanced setup for my car but am confused what the best way to setup the adjustment holes on these bars.
I understand the non-MRCs have a much smaller rear bar. Is it because the spring rates in the rear are much stiffer compared to the MRCs so the ride is balanced out? If that's the case, would adjustments on aftermarket sway bars be much different on an MRC vs a non-MRC car?
Front 28mm
Rear 31mm
Pfaftd
Front 35mm
Rear 32mm
The Pfadt set fixed the soft front end issues. Turn-in is much more precise now. I am using the softer of the two front bar setup. At the rear I am using the mid-position. The car still displays mild understeering tendencies but, being in the right gear at the right RPM during cornering allows for the torque to be used to control any understeering tendencies. Besides, on a street-driven car it is always a good practice to tune-in some mild understeer for safety.
The one thing I ended up doing was re-installing the factory end-links at the rear bar. The Pfadt rear bar does not line up properly enough with the control arm mounting holes and their end-links were binding, resulting in some popping noises. Since putting back the factory links, no problems.
I haven't experienced that endlinks issue. It mounts up fine and so far haven't heard any noise. You mentioned you have a base model. Which originally came with a different size stock bar than mine. I'm assuming that GM put that bar on for a reason and adjusted the dampers and springs to balance out the car. With an MRC car, they've increased the rear bar size probably because the dampening and rebound are adjusted differently from the base model. So since there are so many variations with our cars in terms of sway bar sizes, I'm just curious how aFe did their tuning on these bars. I'm thinking if I were to use the same settings you are using I would get a totally different result considering I am using a different damper than you are. That's why I'm very curious which car aFe used to test their bars on.
The smaller rear bar on the non-MRC Z51 car follows the same philosophy, making the car for the moderately skilled driver who values more precise handling and will actually lightly use it over winding roads.
The MRC was made for the top tier drivers who might even take their cars to the track and demand the most neutral and quickest handling that GM is willing to release. But, GM being conservative and wishing to avoid lawsuits over a nearly neutral handling car and its consequences, still retained a somewhat soft front end that discourages hero-driving.
I would not worry about which model the Pfadt bar was tuned for. That is why it is adjustable to give you a wide range. I use non-MRC Z51 shocks with the base springs. I am not convinced that there is much differences in the spring rates between the base and Z51 models. Also, I always favored softer springs and stiff sway bars for best surface compliances. Same as I prefer the 18&19 tire combo over the 19&20 for better tire sidewall compliance as well as for rim protection. For me the above setup provided a great improvement over the MRC bar setup. So, I suggest to start off with my settings and keep testing the car on a winding road until you find the combo that you feel comfortable with. I am a very aggressive driver, with decades of SCCA track racing experiences and am rather happy with this setup. If I raced the car, I'd go stiffer with the suspension, in general.
I am rather confident that I see GM's strategies correctly. Particularly in lawsuit-happy America very, very few manufacturers dare building a suspension with ultimate handling. Not because they could not, it is because they know that a neutral handling car is dangerous in the hands of drivers with less than pure racing skills. One just have to remember decades ago when Porsche got sued over the truly dangerous handling of its rear-engined 911 that killed a good number of people.
You are also incorrect when you appear to judge the car's handling capabilities on the G-forces that they can pull. Just as, or even more so, important how quickly and how fast the car transitions between left and right turns. A car with insufficient sway bars will lean too much, takes forever to transition from that leaning to leaning in the opposite direction. The car will feel like a pig on wheels. Swaybars actually reduce maximum grip but, more than pay back by allowing almost instantaneous directional transitions.
I will also say that dry sumps are overkill for street cars. For many years I raced cars on high G-force slick tires with wet sumps and never any starvation for oil, never a drop in oil pressure, never any resulting engine failures. That, despite revving those engines to 10K RPMs. The times when oil pans were not constructed to prevent oil starvation during hard cornering have passed decades ago. Much of the reason for dry sumps is rather to be able to install the engine lower in the chassis and to gain minute power by reducing parasitical losses due to the oil tracking paths of a sump car vs. dry sump.
Real life handling, road or track, hardly ever decided by max g-force grips. Sure, a car with smaller, or no, swaybars may actually show higher grip due to the larger weight transfer into the outside tires but, on a tight winding road or track it would be outclassed by a country mile by a much faster transitioning car.
Springs have their roles in the suspension and swaybars also have their roles. Using springs to control body roll is not the way to go. You would end up with springs so stiff that the ride would be unbearable for most street driven applications and even for tracks with less then perfect surfaces.
- OEM FE3 bars
- OEM FE4/5/6 bars (with different bushings per suspension code).
- GM T1 bars (I have them on sale; %40 stiffer up front than FE3; same rear bar as FE4/5/6; unique bushings)
- LG G7 bars (40% stiffer than FE4/5/6 bars, with front having an even stiffer setting with second hole)
- Pfadt bars
Anything else?
- OEM FE3 bars
- Pfadt bars
Anything else?
its been a few years now. do we have more info on sway bars mainly the pfadt bars
***note*** The Z06 and Z07 use identical swaybars as the Z51 w/MRC.
C7 base Stingray
Front - 26.2mm (hollow, 7.85 lbs)
Rear - N/A
Rubber bushings
C7 base Z51 ($300)
Front - 28mm (hollow, 7.95 lbs)
Rear - 26.5mm (hollow, 6.9 lbs)
Polyurethane bushings
C7 Z51 w/MRC ($300)
Rear (Z51 w/MRC) - 31mm (hollow, ? lbs)
Hotchkis ($400)
Front - 32mm (hollow & fixed, 9.2 lbs) +35% stiffer vs. all Z51
Rear - 33mm (hollow & 3-way adjustable, 9.0 lbs) +20-70% stiffer vs Z51 w/MRC
Polyurethane bushings (reuses stock brackets)
Reuses stock end-links
aFe PFADT ($732)
Front - 35mm (hollow & 2-way adjustable) +??% stiffer vs. all Z51
Rear - 32mm (hollow & 3-way adjustable) +??% stiffer vs. Z51 w/MRC
Polyurethane bushings & CNC brackets
Includes heavy-duty end-links
LG Motorsports ($750)
Front - ??mm (hollow & 2-way adjustable)
Rear - ??mm (hollow & fixed)
+45% stiffer vs. Z51 w/MRC (for the set)
Optional heavy-duty end-links (+$245)
Chevy Performance T1 ($600)
Front - ??mm (hollow & fixed, ? lbs, +40% stiffer vs. all Z51)
Rear (same as Z51 w/MRC) - 31mm (hollow & fixed, ? lbs, +20% stiffer vs. base Z51)
