Cooling Rings
Old Mar 2, 2016 | 12:07 PM
bobs-z51's Avatar
bobs-z51
Default Cooling Rings
Has anybody seen a package com with there z51 called Front rotor cooling rings part# 23184111? Do I need to install them?
bobs z-51
Old Mar 2, 2016 | 01:08 PM
Boiler_81's Avatar
Boiler_81
Cooling rings are for track use only. They are to be applied prior to running on track and are to be removed when going back to the street. Z51s are delivered with cooling rings in the rear hatch area. Their usage is covered in the owners manual.
Old Mar 2, 2016 | 04:07 PM
robert miller's Avatar
robert miller
Old Mar 2, 2016 | 11:57 PM
T-TOP TOM's Avatar
T-TOP TOM
Why should they be removed when being driven on the street?
Old Mar 3, 2016 | 12:05 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
From the manual:
Do not leave rotor cooling rings installed after a track event, as this can cause corrosion with long-term use. Rotor cooling rings are for track use only. Track driving without the rotor cooling rings may result in brake pedal fade.
Old Mar 4, 2016 | 09:47 AM
sdcnews's Avatar
sdcnews
Default ok to drive back from track with cooling rings
When at Spring mountain I asked if it was OK to install cooling rings and drive to the track . In my case that would be from Pennsylvania to Bowling green. They said that would be Ok, just don't leave them on for an extended period.
Old Mar 5, 2016 | 08:05 AM
Boiler_81's Avatar
Boiler_81
I agree with this. Short term will not be an issue. They just should not be left on permanently.
Old Mar 5, 2016 | 08:59 AM
ap6954's Avatar
ap6954
Purely a corrosion issue due to dis similar metals. Leaving them in is not an issue. If you don't drive your car in inclement weather or salted roads it won't matter. Especially if you remove your wheels often to clean rims, or check/change brakes. I left mine in for a year. Removed them when I bought upgraded rotors and the cooling rings looked new. I had only driven in the rain a couple of times and I live in the south.
Old Mar 5, 2016 | 09:15 AM
RussM05's Avatar
RussM05
Also they are attached to the rotors with steel bailing wire. It will rust so won't last long term.
Old Mar 5, 2016 | 06:04 PM
VThokies's Avatar
VThokies
If you track your car often it won't hurt to leave them in all the time. The rotors will not last long enough to worry about corrosion from the rings.
Old Mar 5, 2016 | 08:16 PM
bikevette's Avatar
bikevette
I leave mine on as I track a lot in the summer. No corrosion visible and the wire that comes with the rings is stainless steel. Not a forever corrosion preventative but helps. A little spritz of brake cleaner every so often helps too.
Old Mar 6, 2016 | 09:32 PM
dino333's Avatar
dino333
.032 stainless steel aircraft lock wire should do just fine.
To Cooling Rings
