Nav question
Old Oct 15, 2017 | 08:52 AM
Bfon1987's Avatar
Bfon1987
Originally Posted by etaylor14
Bfon I did not lose any functions but actually gained a couple I now have traffic and weather. You are correct on the 2014/2015 model years but there was a note saying to call them if installing in a 2014/2015. I have a 2017 so no problems.
E.T.
OK you sold me with that last post. If you could, please provide website for me to purchase. As a sidebar, (according to other post) with the proper trim tools the speaker cover can be removed w/o removing the pillar. Either way no big deal. this looks like a simple swap out. Thanks Again!
Old Oct 16, 2017 | 10:55 AM
etaylor14's Avatar
etaylor14
Bfon see post #15 that is where I purchased and the price..
Old Oct 18, 2017 | 05:03 PM
Bfon1987's Avatar
Bfon1987
Default IO6 HMI Upgrade
Thanks to all that offered input to gain actual Nav. Ordered unit and it's on it's way. Talked to customer rep before placing order, and she sent me link for a 2016 HMI model. She said the 2015 module was slower. They also had listed a 2016-2017. Not sure the difference except maybe the maps are more up to date.
FYI: http://www.ebay.com/itm/2016-OEM-FAC...item33c1774acd
Old Oct 24, 2017 | 04:15 PM
Bfon1987's Avatar
Bfon1987
Just installed. Everything works just as if factory installed. Pictures attached. No loss of XM or driver preferences.Nothing to reset. Phone took 30 seconds to pair. Nav location spot on. Instead of splitting with OnStar antenna used dedicated antenna. Truly a plug & play.
Before #1
Before #2
After #1 (Onstar Nav Gone!)
After #2
Old Oct 24, 2017 | 04:18 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Now wasn't that easy to do!???
Glad it worked out for you.
Elmer
Old Oct 24, 2017 | 08:42 PM
Bfon1987's Avatar
Bfon1987
Elmer
Yes it was and thanks.
Old Dec 16, 2017 | 10:36 PM
bsedwebt's Avatar
bsedwebt
Got a programmed I06 unit from an ebay seller for $580 and installed today thanks to you guys. Took less than an hour - LOVE IT
Old Dec 21, 2017 | 01:39 AM
Martman C7's Avatar
Martman C7
Does anyone know if there is a Nav solution for 2018 owners? I have a 1LT without nav, and all the links I've seen only show up to 2017. I tried the units listed on ebay, and when I select my yr. and model of car, it says it's not compatible with my car.
Any help is greatly appreciated.
Old Dec 21, 2017 | 10:43 AM
etaylor14's Avatar
etaylor14
If you call Digital Dash Solutions at 860-792-8021 they can answer your question. I got my io6 module from them that's all they do is electronics.
Old Dec 21, 2017 | 12:33 PM
Bfon1987's Avatar
Bfon1987
Call Digital Dash Solutions.Ask for Jenni. She's well versed on the Nav issues. Digital Dash & FixMyGauges are the same company, different department. (860) 583-0629
Old Dec 21, 2017 | 12:50 PM
Bfon1987's Avatar
Bfon1987
I agree with etaylor14. Dilly-Dilly! When I called I had the same problem with their drop down menu. They not only set me on the right path but offered a better module at a cheaper price than what I was looking at. Be sure to ask if there are any functions you may loose with the upgrade.For example . Z51's have different software than base even though the infotainment system appears the same. Different software - possibly different functions. The more research you do now, the less problems later.
Old Dec 22, 2017 | 10:16 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
My 2017 displays NAV in my non NAV equipped car from my iPhone using Apple Play! I don't have OnStar.
