Front end popping when cold
Old Dec 26, 2016 | 09:06 AM
deichenberger's Avatar
deichenberger
1st Gear
Default Front end popping when cold
I have a 2016 Z51 with 1300 miles on it and first thing in the morning, when backing up and turning the wheel to the left or right there is a severe front end popping from the wheels. It also occurs when going forward and making a hard left or right turn. Symptoms seems to go away once everything has warmed up and I have driven a mile or so. Is this normal?
Old Dec 26, 2016 | 09:09 AM
spearfish25's Avatar
spearfish25
Yep
Old Dec 26, 2016 | 09:17 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Yes, it is normal for the steering geometry and the wide sticky tires on the car. Notice that the tires do not match in the angle of the turn when you are turning sharply. At slow speed, it makes the tires hop.
Elmer
Old Dec 26, 2016 | 09:32 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
It is totally normal and has been discussed many times on several threads. Do not worry about it.
Old Dec 26, 2016 | 02:13 PM
davepl's Avatar
davepl
Normal, as stated, and here's why:
https://en.wikipedia.org/wiki/Ackerm...ering_geometry
To Front end popping when cold
