Car hesitates
Old May 9, 2017 | 01:09 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Default Car hesitates
The car doesn't miss a beat at WOT but at low to medium acceleration it acts different. Like it hesitates almost like the computer is trying to figure it out. Its probably just me and I am not use to the a8. All my previous corvettes were a6 or m6. Does this sound normal? Some have said the computer needs to learn. After 1500 miles you would think it would figure it out.
Old May 9, 2017 | 01:32 PM
\Boost Monkey/'s Avatar
\Boost Monkey/
Like A8 gear hunting?
Old May 9, 2017 | 01:43 PM
50th year's Avatar
50th year
not sure if its gear hunting. I have never experienced a car gear hunting. Its almost like its missing but its not.
Old May 9, 2017 | 02:06 PM
Elite275's Avatar
Elite275
Mine had a hesitation/stumble like you speak of after installing a ported throttle body. It took some playing with the tune to get it ironed out. Like you, at WOT it was fine, but just cruising along it obvious.
Old May 9, 2017 | 04:34 PM
\Boost Monkey/
High gear transmissions tend to hunt more often the older 6's when you modulate the throttle or brake on and off or whatever. This feels like the car shifting back and forth between gears or delay in engagements (up or down shifts) into the gear you would think should be demanded.
Old May 9, 2017 | 07:43 PM
davepl's Avatar
davepl
A8s don't hunt in our cars - that's the beauty of our torque modelling. We make so much torque that it rarely has to change gears without a substantial change in load, and it's good as selecting the correct one, so far as I can tell.
If you tied the A8 to a little turbo four cylinder, then it'd hunt a lot I imagine. But mine sure doesn't.
Old May 9, 2017 | 08:45 PM
djnice's Avatar
djnice
Mine is GS so could be a little different. I suppose there is some hesitation if you don't press the pedal far enough and get it to kick down a gear. When cruising at neutral throttle it always wants to shift the highest gear possible and then lock the clutch. I am really wondering if the LT4 trans is a totally different feel.
Old May 9, 2017 | 09:12 PM
\Boost Monkey/
Light throttle (like in traffic) with modulation and mine hunts all the time, as does every 8 or 9 speed I've ever driven, no matter the car, including my Ram truck. Ny A8 hesitates horribly downshifting in traffic as well as holding gears too long.
Old May 9, 2017 | 09:24 PM
djnice's Avatar
djnice
Also if the OP is letting AFM turn on then it will hesitate even more. Might try running in M and stay no less than 2,000 rpm then see if it hesitates.
To Car hesitates
