Can a PDR be installed
Old Jul 23, 2017 | 08:35 PM
X25's Avatar
X25
Sr.Random input generator
This is with a $15 app, GoPro, and a $13 OBD II Bluetooth reader. You don't have to try to mimick the OEM system.
I can always change my layout, too. I overlay the data on video using RaceRender.
One very important difference: as you can see, I can see how the current lap's delta is compared to best lap so far on the phone screen during the lapping. The PDR system, inexplicably, doesn't provide this vital information.
Old Jul 23, 2017 | 08:42 PM
dmaxx3500's Avatar
dmaxx3500
can you give out a list of what parts and wiring you used?
Old Jul 23, 2017 | 08:54 PM
X25's Avatar
X25
Are you asking me? No wiring necessary.
  • Vgate i2 BT OBD II reader (just plug in to OBD Port to read engine/car data).
  • BT GPS transponder ($70-150; I use XGPS160)
  • Your favorite action video camera.
  • Your Android or iOS device to log the data.
  • Finally, RaceRender PC app to put it all together. There are other apps also available, like DashWare.
All in all, it's very cheap, and you get to track your sector and lap delta times live during the session, which is a must for me (and which is why I skipped PDR). Some like the simplicity of PDR, tough, so YMMV : )
Old Jul 24, 2017 | 10:19 AM
rrsperry's Avatar
rrsperry
Anything CAN be added. The question is, is it cost effective? If you don't own the car yet, no, it's probably not cost effective. Just buy a car that has it. Why bother buying new if you are going to track the thing? There are a metric crap ton of very low mileage, used C7's with PDR, that have already taken the depreciation hit.
Yes, you can use aftermarket stuff, yes it will be functional. No, you probably can't use the Cosworth video tools...
Old Jul 24, 2017 | 10:20 AM
village idiot's Avatar
village idiot
Honestly, the best part of the PDR is its camera/mic location. Other than that, I think aftermarket is probably better.
Old Jul 24, 2017 | 10:46 AM
dmaxx3500's Avatar
dmaxx3500
sorry,no,the factory install
Old Jul 24, 2017 | 11:57 AM
08velocity's Avatar
08velocity
St. Jude Donor '13
https://www.youtube.com/watch?v=TwgQ5UiRAIY
Where is your GoPro mounted ?
Old Jul 24, 2017 | 12:41 PM
village idiot
I'm guessing his cross bar
Old Jul 24, 2017 | 02:08 PM
X25's Avatar
X25
Yep, with an extension bar to raise it.
Old Jul 27, 2017 | 09:49 PM
Jetblackc6's Avatar
Jetblackc6
Originally Posted by DAVE396LT1
Why would someone claim this and then bail? So weird...
not a claim this is done and working i've been a little busy with rebuilding corvette's . i will post the write up soon guys give me some time
Old Aug 15, 2017 | 10:34 PM
pdkwork's Avatar
pdkwork
Any idea if you can retrofit the PDR? Jetblackc6, even if you don't have the time to write up you process, can you tell us how much the parts cost?
Old Aug 16, 2017 | 12:52 PM
smajicek's Avatar
smajicek
excuse my ignorance what is a cross bar?
Old Aug 16, 2017 | 01:48 PM
  #33
X25's Avatar
X25
It's just the harness bar that crosses from side to side, right behind the seats : )
Old Aug 16, 2017 | 11:52 PM
  #34
Drew27's Avatar
Drew27
updates
Old Aug 18, 2017 | 12:54 PM
  #35
osunick's Avatar
osunick
There are a couple advantages to PDR, namely standard OBD channels do not share steering angle or brake pressure, which would be really nice to have for analysis. These are exposed as extended OBD PIDs, but I believe the only setup that will pull this data is the AIM Solo DL with a gopro and racerender, or for an all in one solution, the smartycam standalone: https://store.m-world.us/collections...nt=16353995265
The smartycam setup is far superior to PDR in terms of data collection and analysis tools, but isn't cleanly integrated as you'll need to run a cable to OBD and to power, but that's handily available in the cargo area.
The easiest thing to do is get a RAM suction iphone mount and run Harry's on your phone. It captures video and renders the overlays in phone, and you can post on social/youtube immediately. No additional hardware required. Excuse my terrible driving, but here's an example:
The built in GPS is adequate for hobby use, but you can get a 10Hz GPS and get much more accurate position data in the app, just connects through bluetooth.
Old Aug 22, 2017 | 07:03 PM
  #36
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
pdr can be added.. I installed pdr into my 16 z06 buying all parts needed used and about 2 hrs of wiring. im also working on a write up with pics of it installed and should have it done in a week or so
It has been a while and I know you are busy fixing vettes so if I brought you my 16 Z06 1LZ what would it cost me for you to add it (nav and PDR) to my car and how long would it take?
Bill
Old Aug 24, 2017 | 12:41 AM
  #37
CT Grand Sport CE's Avatar
CT Grand Sport CE
I am currently at Spring Mountain and today they went over the basics of the PDR. Some people in class asked if it can be added to a car that doesn't have it. The instructor said GM's response was yes, for $9000.
To Can a PDR be installed
Old Sep 21, 2017 | 09:22 PM
  #38
Drew27's Avatar
Drew27
Paging
Old Sep 22, 2017 | 07:31 AM
  #39
fatsport's Avatar
fatsport
Don't know much about GoPro - which one would you recommend? I would think that video stabilization would be a must. Thanks
Old Oct 25, 2017 | 09:01 PM
  #40
Drew27's Avatar
Drew27
What happened to this guy?
